Thread: Taylor vs TF-100 Regents
    Central Connecticut
    159
    Is the R-0013 fluid for the CYA test the same as sold by Taylor vs. Tf Kits ? I have the Tf-100 kit, but need more R-0013 regent. Taylor is selling the R-0013 regent 1 pint (16 fl oz) for a little less than TF kits sells the 8 oz.
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Mar 2009
    Macon Ga
    77
    Re: Taylor vs TF-100 Regents
    Yes it is the same. I use both and can get the Taylor locally.
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    Jul 2010
    Las Vegas, NV
    15
    Are they the same test kits? The reason I ask is I'd like to purchase the TF-100 but $18 for shipping is definitely on the steep side. If I buy the Taylor kit locally will I be able to get the same results?
    Approx. 18'X24' Pebble Tec free form shape.
    Jul 2009
    Blue Springs, MO
    105
    I'd check the size of the reagents you get with each test kit. The TF-100 comes with bigger size reagents to begin with than the Taylor version. I made the mistake of buying the one from Leslie's locally.
    24'x4' AGP Round
    S166T Hayward Sand Filter
    S48K2A2 Hayward Pump
    22,553
    If you do decide to go with the Taylor kit (which I don't recommend) be sure it's the K-2006. A lot of stores stock the K-2005 and tell people it's the same but it's not.
    As said above, the reagent sizes are more in line with what you really need in the TF-100 than in the K-2006.
