Results 1 to 16 of 16
Thread: Opening up a pool
    Opening up a pool
    I can't find a place to start a new topic, maybe someone here can help me
    We are opening up a pool that has been closed for years...We have done all the patching and now working on the pump...How do I know how much sand I need to use to replace the old
    Thanks for any help
    Spilt off from another topic to create its own.
    257WbyMag - Forum Moderator
    Legacy Rectangle AGP, 13' x 25', 11,200 gal
    Hayward Power-Flo Matrix Pump, 1.5 hp
    Hayward XStream Filter, 150 sq.ft.
    Mojave Desert Heating System 8-)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Need Help
    Quote Originally Posted by shielda
    Thanks for any help
    If there is a label on the filter then there should be some information on there. If you can find the brand and model number that will help us tell you how much sand you need. If you can't find that information take a picture of the filter and post it here. Also measure the height and circumference of the filter and post that information as well.
    Whenever you want to start a new topic/thread, click on "Board index". That will take you to the forum menu. Find the Forum that best suits your needs and click on that. In the upper left quadrant of the new page will be a blue button called "New Topic". Click that and it will bring up a dialog box for you to create your thread and post your question.
    Love TFP? Become a
    TFP Supporter!
    22,548
    Re: Opening up a pool
    Welcome to TFP.
    Give the specs, model, etc. on the equipment and we can possibly help you. Without that there's really no way to tell.
    There are people here with filters that hold from 50# to 925#'s of sand.
    24' x 52" Round AGP. 2hp/╝hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Is is a :
    Tagelus, Model TA-60
    Looks like te Filter Area is 31.50 - metric 29 but I am not sure of that...the reading is hard to read
    It doesn't mention anything about how much sand ...
    Horizon 45
    Maybe I can go measure this evening
    Thanks
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    22,548
    No need to go measure.
    The Tagelus TA-60 takes 325 lbs of sand
    or 50 lbs of pea gravel & 275 lbs of sand.
    The freeboard (distance between the top and the sand is 10┬╝".
    Oh thanks so much...I appreciate the help
    I measured the tank...It is:
    34 inches tall
    74 inches around
    Do you still think I need that much sand for it?
    22,548
    As long as it's a TA-60 it needs that much sand. Be sure to get #20/21 filter sand too.
    Ok...Thanks...
    We got the sand...waiting now for the gaskets to come in...We are replacing all of them since the pump hasn't been used in so long...I am getting excited that everything is coming together
    22,548
    Good for you. While you're waiting on those gaskets read through pool school a few times especially the part about levels and maintenance.
    I sure will...
    Pump gaskets came today...Hubby put them on and everything back together...the pump is still not picking up...sucking air somewhere...he thinks it is in the swimmer line
    22,548
    Be sure it's not the pump basket lid o-ring. Clean and lube that real good.
    If you suspect a place in the skimmer piping you can run water over it from a hose while it's running. If it primes then you know you've found your leak.
    We did put a new pump basket lid o-ring...I will give this information to my husband when he gets home from work...we have everything turned off right now and I am not good with electricity
    thanks for the help
