Results 1 to 7 of 7
Thread: Am I done shocking or should I continue?
    Jun 2010
    Washington, DC
    56
    Hi. My background is here and here. I have now realized I have a filter problem which is probably why my water is still very cloudy. It looks clean but oh well until that filter is replaced there is nothing I can do about it. Here's the latest test results:
    FC: 10
    CC: .5
    TA: 100
    PH: 7.4
    CH: 580
    CYA: <20
    I lose about 1 or <1 ppm FC overnight and around 1 ppm during the day. CC has remained .5. This is the pool set up.
    Skylights right above the pool. While it does not get direct sunlight all day it does get light from noon to maybe 3 pm. Unfortunately, the skylights can't be opened.
    EDIT: Here's a picture of the skylight:
    My question is (and please keep in mind that I have an indoor pool) I have been shocking for about a month now. Am I done shocking and just accept the fact that the water will continue to be cloudy until something is done with my filter? Can I swim? I am aware of the safety issue with swimming in cloudy water.
    Thoughts? Thanks again.
    Pool size = 24,000 gal.; rectangular 3 ft shallow, 8 ft deep
    Jacuzzi Sand Filter (can't find the model) flow rate 60, Pentair Super Flo, 1HP
    Pool is inground/indoor and white plaster, TF-100 Kit
    Re: Am I done shocking or should I continue?
    Just to clarify -- you have an FC of 10 and zero CYA due to being an indoor pool?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jun 2010
    Washington, DC
    56
    Oops I forgot the CYA, it is <20. So yes my CYA is low because it's an indoor pool. So I'm debating if I can go ahead and let the FC fall below the shock level.
    Yes, you are done shocking. The criteria are: FC loss of 1.0 or lower overnight, CC at 0.5 or lower, no visible algae.
    Jun 2010
    Washington, DC
    56
    Yey! Thank you Jason, I think I'm going swimming tonight. Oh I have another question. Do you think I should lower my ph from 7.4 to 7.2 and my TA from 100 to maybe 90 with my CH being so high (580)? Thanks again.
    Your PH is alright where it is now. I would keep the PH between 7.2 and 7.5 for now, and longer term work on lowering the TA level a little.
    Jun 2010
    Washington, DC
    56
    Thanks again.
