Hi guys,
first post here
So basically I am buying an above ground pool this week, 18 feet diameter, with salwater system
Being completely new to pool altogether, I'm not always sure the right questions to ask the salesman, they seems to give the least amount of info and try to make everything sound so simple, however after doing a little research I can see there alot more to it.
after having shopped around and asking a few questions, I am have the choice of 2 salt water systems (both about the same price), 1. Hayward aquatrol, 2. Zodiac clearwater for above groud pools
anyone have an opinion on which would be a better choice?
also the system come with a filtration system that uses catridges (apparently no need for backwash) is this a good system?
also I live in montreal in montreal (cold winters) should this have any bearing on my decision making
finally, once the pool is installed, how long does it take before I can actually swim in it, how long does it take before the water temp gets to swimable temp
thanks for you help
first post here
thanks for you help
