Thread: New Inground Pool Started 2010-07-23
    I will upload a bunch of pics tonight.... Had a camera issue and now I need to go build a fence.
    The pool is going to be 18x36
    6' stairs with jets
    UV System
    1 Automatic Surface Skimmer
    30mil Full Print Liner
    Sweep Fiting
    Jandy LX1 250 Heater
    2 Main Drains
    1hp Sta-rite pool pump
    Tiger Shark Pool Cleaner
    Solar Blanket
    2 Adjustable Return Fittings
    Resin Pool Ladder
    Maintenance Kit
    Cartridge Filter
    Double Aqua Lamp
    Day 1:
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Mar 2010
    Western North Carolina
    77
    Re: New Inground Pool Started 2010-07-23
    this is where the fun starts.
    Post some specs, and some wider pics.
    16'x34' IG Vinyl. 1.5HP Hayward 2spd. Hayward S244T sand. Nitro wall climber.
    Day 1
    Day 1
    Day 1
    By the end of day 1 they dug the hole for the pool and set up the pool walls and stairs.
    While the pool was getting dug and set I had a fence guy out to dig and set my 6x6 fence posts. He finished about 7:30pm and Day 2 my dad and I started away on the fence .
    Stand by for day 2 pics ..............
