Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: IntelliChlor
    IntelliChlor
    I have been having to bump up the setting a lot lately and now I am at 100% with a 8 hour pump time.
    Pool:
    13500 gallons
    PT Plaster
    Whisperflow 1.5hp
    DE filter 60 sq ft
    IntelliChlor 40
    Water temp 88 degrees
    T chlorine 0.3
    Free chlorine 0.0
    PH 7.8 (ADDING ACID)
    TA 120
    Calcium hardness 333
    Stabilizer 50
    Salt 3800
    Phosphates 500
    PB said to shock pool, add 35oz of commercial grade PHOSFREE and increase pump time to 12 hours. If this doesn't correct it he will replace Intellichlor which was just replaced 4 months ago.
    Does this sound like a solid plan or is something missing?
    18/20x40 free form in ground 30,000 gal gunite sand filter, 1.5 hp pump with antique Polaris cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: IntelliChlor
    Phosphree is a way pool stores make money. Phosphates ARE algae food, but if you maintain proper FC levels, they are irrelevant.
    Once your FC drops below the "min" recommended level (see our CYA chart), which yours has, algae/organics can get a foothold and the SWG can't keep up.
    I agree with shocking the pool (with liquid chlorine only), but then I would do an Overnight FC loss test to confirm what is happening. The SWG must be off for you to do so, and you must have your own test kit. Those results look like pool store results....
    Here are a couple of links to start with:
    Chlorine CYA Chart
    Test Kit Comparison
    Water Balance for SWCGs
    Shocking Your Pool
    Post back if you have any questions or need further clarification on the information in the links.
    22,542
    Re: IntelliChlor
    Ok, I'll just agree with everything FPM said, except! Ok there is no except. Just do as she says!
    Dec 2009
    Central Massachusetts
    2,690
    Re: IntelliChlor
    I have the same IC-40 on a pool thats the same size as yours. The IC-40 should, with an 8 hour run time, keep up your FC levels just fine at 50% "on time" or less. Do what PoolMom suggests, that will give you an idea if you have organics in the water eating the FC as soon as its being made. Your CYA of 50 ppm should be ok to hold the FC. Some might say to bump it up, but what you have there now should allow more than 0.3 ppm to accumulate if there are no organics in the water. These also look like pool store test numbers too which can be inaccurate. How confident are you in the CYA actually being 50? Could it be lower?
    Just to reiterate, read the links FPM posted, shock with liquid, and see if it holds overnight. You should also think about getting a good test kit. An overnight loss test after shock is really hard to do with pool store testing or even the basic OTO tests from walmart.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Re: IntelliChlor
    Thanks for all the comments.
    Yes, the results are from the pool store. I wanted to get my own test kit, as described on here, but my PB didn't have the recommended kind. I then went to Leslie's to get one and the guy talked me out of it by saying "just use the cheap test strips once a week and bring in your samples every 2-3 weeks".
    They had me use granular chlorine for the shock yesterday, I had been using bleach up until then.
    The Phosfree jumped up my filter by 12 psi last night which kind of PO's me. The **** cost $64 so if it is "snake-oil" I will take the rest back and demand a refund.
    My PB is a really stand up guy and always handles issues within hours, he won't hesitate to switch out the IC40 but I just want to make certain it is the issue. Last year I ran 8 hour pump times at 35% and my chlorine stayed between 2-3 all the time.
    Dec 2009
    2,690
    Re: IntelliChlor
    Quote Originally Posted by ParadigmDawg
    What was your CYA level last year? At 50ppm, thats not enough FC. With 50 ppm, your target FC should be around 4-6 and never let it drop below 4. My bet is you IC-40 is just fine but you have a nascent algea bloom that eating chlorine as fast as it's made. Follow FPM's advice and report back.
    Take the phosphate remover back and use the left over money to buy a good test kit. Ditch the strips
    Re: IntelliChlor
    I don't know what my CYA was last year, I trusted that the pool store was leading me properly.
    Would I see evidence of a algae bloom? My water always looks good and is very clear unless it's difficult to see because of the PT.
    I will use the advice given, thanks for all the help.
    Quote Originally Posted by bk406
    Re: IntelliChlor
    Normally you would see an algae bloom. But with a SWG and CYA around 80 you can get into a situation where the SWG is keeping the algae in check enough that you don't see it and yet the SWG never completely kills off all of the algae. In this situation there water won't be quite as sparkling as usual, but that is a very small effect and not always obvious when you don't have another pool right next to it to compare to.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    Re: IntelliChlor
    paradigmdawg, how goes it? just for something to compare it to. i also have the IC 40 and a pump run time of 12 hours per day. it's currently set on 65% which has been keeping my FC around 7.5 or 8.0 for a month or so. I try to keep my CYA between 70-80 and according to the pool calculator that puts my FC range between 6-11. I always try to stay somehwere in the middle.
    Good luck with your issue. AWESOME pool by the way!
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    Re: IntelliChlor
    Thanks AJONES. I guess I can post a couple of pictures of it since you brought it up.
    Quote Originally Posted by ajones02
    Re: IntelliChlor
    Ok, I just got the Leslie's Chlorine FAS-DPD Service Test Kit. Looks like it may be designed for people with a higher IQ than me so I guess I better start reading and learn how to do all this on my own.
    Quote Originally Posted by frustratedpoolmom
    Chlorine CYA Chart
    Test Kit Comparison
    Shocking Your Pool
    Re: IntelliChlor
    New test results using Chlorine FAS-DPD Service Test Kit
    T chlorine 7
    combined chlorine 0
    PH 7.6
    TA 110
    Calcium hardness 290
    Stabilizer 35-37 (difficult to see exact reading)
    I am hot and would like to jump in.
    Dec 2009
    2,690
    Re: IntelliChlor
    Ok that doesnt look too bad. How did you get your CYA numbers?
    Since you have the FAS-DPD kit, turn off you IC-40, but run the pump. After dark, measure the chlorine again. In the morning before the sun hits the pool, measure it again (leave the IC-40 off all night). If you have no organics, the FC should be within 1 ppm of what you measure tonite.
    BTW, how did you get the FC up to 7? Did you add some bleach?
    Re: IntelliChlor
    For CYA, I followed directions on the kit where I mixed the reagent and then slowly added to the comparator tube until the black dot on bottom just disappeared.
    I shocked with 1lb of refresh last night before I joined this site and asked questions.
    Ok, IC-40 is off and pump is running. I will recheck chlorine as described.
    Thanks for the help!
    Ok that doesn't look too bad. How did you get your CYA numbers?
    Dec 2009
    2,690
    Re: IntelliChlor
    Ok, refresh is just cal hypo, so that should be ok. From now on if you need to shock or raise your FC just use bleach.
    Re: IntelliChlor
    Oh, one more question for now.
    Since the PhosFree increased my filter pressure form 11 psi to 20, do I need to go ahead and backwash (DE) or will this stuff slowly dissolve and pressure will drop? I backwashed and added DE about 3 weeks ago.
    Re: IntelliChlor
    Yes, backwash. You should backwash any time the pressure goes up by about 5 or 6 over where it started.
    You should read the CYA test by multiples of 10, ie the labeled mark on the tube closest to your water level. So your CYA level is 40. The CYA test doesn't have enough precision to be able to determine the CYA level closer than that.
    Re: IntelliChlor
    Thanks.
    So backwash even though it was the PhosFree that caused the increase in pressure? It has actually started to come back down now and is at 15 psi; so that's a 5psi drop from the morning. That PhosFree must be some sticky, nasty junk.
    Should I add some stabilizer? What's the best to use?
    Dec 2009
    2,690
    Re: IntelliChlor
    Dont add any stabilizer until you determine if you need to shock based on the overnight loss test you are doing now.
  20. Back To Top    #20
    Re: IntelliChlor
    Yes, backwash.
