Results 1 to 10 of 10
Thread: thinking of upgrading my pool a little
    Guest
    ok help me along in this, but i was figuring on adding and changing some stuff.
    what i want to do
    change the filter and pump, what do you think is the best?
    intelliflo 4X160
    northstar 2 hp these are what i am looking at, are these good or are there better ones out there
    filter
    quad D.E.â„¢ Cartridge Style Filter. is de better though?
    would like to automate it all with this too
    IntelliTouch® - ScreenLogic®
    EasyTouch® Systems
    auto clorinator
    - IntelliChlorâ„¢ Chlorine Generator
    Maybe a ThermalFloâ„¢ Heat Pump, but i would like one that cools too, my pool got to 94 on some days and i went to seven eleven to buy bags of ice.
    i would also like to add a cozy cove spa
    would i need a seperate pump and if i did would another 4x160 be good and with a blower or would just a blower be good.
    thanks for your help, but my equipment is starting to show its age and i think it may be time to upgrade, it is the orig equipment. from 1986
    i am also going to have all the grounding and bonding replaced.
    Mar 2007
    Ontario
    211
    I can't help you with the upgrades. But I would love to see a picture of that bad boy!
    25'x 50' WOW
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Can you tell us a little bit more about your goals? Did you dislike the sand filter or just feel it is time for a change? Do you want more water movement? Or trying to save money on electricity?
    I think of the Intelliflo 4X160 as wonderful for someone who likes to learn all about the pump and adjust the settings themselves. If you want something that simply works without thinking about it I would go with a two speed whisperflo.
    Guest
    well my goals are that my pump is old, the water stays clear and it moves well but my sand is 8 years old and teh filter is from 1986 as well as the pump, i think that a 4x160 would be good for the spa attached to the pool, i would like a filter that filtered better and didn't require me to change the sand out, water movement is fine but only if i shut off one of the returns, and i shut off the one that is down 5 feet and is supposed to circulate better and if i have all four open i get alot less movement, i still get movement but not much, i guess the only reason i would upgrade my pump is for the spa and i figured i might as well go the whole 9 yards on it.
    saving money would be great, it adds 75 dollars a month to my bill, and i dont have a heater yet but would like a cooler too, and i would like to get that shock fixed, i have not let any body swim because of what you guys told me and i miss it so i want it fixed.
    if i get a heater i would like one that is really efficient, i dont want to use a solar cover because we have little ones and all the horror storries i have herd i said NO THANK YOU so is there an alternative to solar.
    Guest
    Quote Originally Posted by haybird
    25'x 50' WOW
    here is where i posted pictures
    http://troublefreepool.com/viewtopic.php?t=2369
    it is so long because the previous owners had a daughter in the olympics and she swam, they didn't want a lap pool only, so they made it long and wide so it would be both a lap pool and a fun pool.
    its great when i want to do laps.
    30,432
    thunder,
    Changing the sand is an unnecessary task. Many folks go ten years without changing. Mine is five years old and I haven't opened the filter in two years....works perfect. I may add some sand next year, if it needs it, but I plan on NEVER changing.
    A single Intelliflo 4X160 should be able to handle everything. One of it's big advantages is that you can dial in exactly how much water movement you want to have. The Intelliflo won't nessessarily save as much electricity as they make out in their ads but it will be reasonably efficent.
    A separate blower will get you more bubble activity in the spa than the pump alone, but venturi jets are quite good without a blower.
    Each kind of filter has advantages and disadvantages. Sand is the simplest to maintain but lets the largest amount of stuff through. DE is the most work to maintain but filters the finest. Cartridges are close to DE in filtering and in between in maintinance. One trick is to add a little DE to a sand filter, which gets it into the fine filtering range of a cartridge filter with only a little added maintinance.
    Since I just changed my filter, hopefully I should not need to worry about this for a very long time, but.... How do you know if it needs it?
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    There is a specific level inside the filter that the sand should come up to, different for each model of filter. Over many years you can lose some sand and if it falls too much below the design level more should be added. Checking this requires opening up the filter, which requires some mechanical inclination. If such things don't bother you it is a good idea to open up the filter every say two years and make sure everything is alright, remove any large bits of debris that found their way inside, and gently break up any clumping.
    Guest
    ok, so i am thinking about ordering the following.
    Intelliflo 4x160
    COzy cove spa http://www.hydrapools.com/cozycove/
    DE filter- i like that it filters the best
    blower for the spa- like the bubbles
    may skip the heater for now but if i dont- here is what i will get- AquaCal ICEBREAKER-H155R
    i like my auto clorinator and dont need a new one so i may keep the one i have.
