Results 1 to 8 of 8
Thread: Nature 2/chlorine feeder question
    Jul 2010
    Central Illinois
    50
    My pool actually came with this duo setup. I have a full understanding of the N2 and will more than likely not use it. The chlorine feeder portion actually is built to hold a chlorine cartridge. My question is...can I break up my 3" pucks to fit in this slot? Hopefully I will not have to keep buying the chlorine feeder cartridges...thanks in advance.
    1) 8500 Gallons (18 foot, 52 inches deep)
    2) Hayward Cartridge Filter
    3) Above Ground Pool
    4) Hayward 2 HP pump
    Jul 2010
    IL
    201
    Re: Nature 2/chlorine feeder question
    Yes you can do that or buy the 1" tri chlor tabs. The cartridge is $12 per and if you buy the tabs and refill them its roughly $3 per fill.
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Remember, the pucks will add CYA, so you can only use them for so long before you get over stabilized.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jul 2010
    Central Illinois
    50
    Thanks to you both...I will watch my CYA real close! The reason that I asked about the 3" pucks is I have a most of a container still full of them...and it looks like they are to big to fit...thus the put in a bag and tap with a hammer to bring them down to a workable size. Do either of you know how long the Chlorine cartridges can last? I know all pools are different...just looking for a very rough estimate under ideal chemistry setup. Thanks again in advance!
    Jul 2009
    Seattle, WA
    89
    If you want to use the the 3" inchers, you can buy a floater cheap.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    Jul 2010
    Central Illinois
    50
    Thanks Grape Ape...I actually still have a floater from my old pool...just not a fan of them. Sounds like I can put them in the feeder...if that does not work I will pull the floater out of retirement at least until I get through the rest of the 3 inch tabs...thanks again to all.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Not sure of the duration of the N2 cartridge but back in the day my Frog cartridge lasted 2 weeks at the most.
    Jul 2010
    IL
    201
    Mine lasts 10 days or so and my dads lasts 6-7 days. He has a ton or swimmers almost daily with 17 grandkids..
