Thread: please help- backfilling question
    I know this topic has been covered before in various threads but I need a definitive answer maybe from a professional pool installer. I just had a 24' above ground pool installed in my backyard and the installers had to dig the pool down 17" on the high end. I now have a trench around about half of the pool and I don't know what to do to fill it in (if I can). Do I need drain tiles?? Can I just use the dirt they dug out?? (I understand about the issue of pressure on the walls with no water in the pool). My yard is sloped away from the pool pretty severely and always seems to drain away and dry up fast. I want to start cleaning up around the pool fairly soon and maybe use up some of the dirt they left behind. I would appreciate any advice someone might have.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: please help- backfilling question
    Make sure it is covered under your warranty first. The ones that are allow you to "bury" the pool up to 2 feet deep. Mine is...........and backfilled with clay and dirt out of the hole.
