I went out to take a dip in the pool and found the pump not running...it should have been because it was supposed to be set for an 18 hour run. It turned out that the circuit breaker in the house tripped. I re set that and then went out and hit the switch...it had power but just hummed...hummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm!
After a backyard barage of profanity that I can only hope was not heard by anyone...FPM knows what I am capable of... I calmly started disecting...I took the pump basket assembly off and then the impeller cover...the impeller moved freely and when I removed it the shaft and motor both turned freely. So I reassembled and took back out to the pool. When I plugged it in it primed up and started pumping right away. So what do you think the problem was? Can anyone let me know if I have anything to worry about, or is it one of those things? Thanks
Cubbybeave...
Cubbybeave...
