Thread: New plaster discolored
    Mar 2010
    San Diego
    24
    Guys....I had the pool re plastered in March and in June added Borax to 50ppm. Now there is a problem with discolored plaster, it looks like an 8 year old pool....gray blotches and streaks.
    The tech from the contractor came and checked the water and filter etc. Of course my water is perfect, thanks to this site .
    He thought a high stabilizer may be the cause, but mine is fine. Now he will have the owner and plaster product reps come out to look. The plaster is white/quartz.
    Question: Is there any chance at all the borates would cause this? Any other complaints?
    Thanks much for feedback....cal
    Mar 2010
    San Diego
    24
    Re: New plaster discolored
    OK doing more reading...sounds like the problem could be "calcium cylicate hydration" causing uneven set rate of plaster???
    Way out of my league here...but it sounds impressive and the symptoms are the same as mine...dark modeling and staining of new plaster...
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Any chance of some pictures? Calcium scale could look that way too, but it sounds like you've got good control of your chemistry.
    Mar 2010
    San Diego
    24
    I know, pictures would help but not in a position to do that right now...believe me water is perfect. More reading also indicates that over-troweling can cause graying. In fact some of my gray stains are in an arc just like a trowel would make. Other stains are more like mottleling or marbleing which articles say is caused by hydration problems at start up. Dunno. Just preparing for a battle with contractor
    Mar 2010
    San Diego
    24
    Well here's what I think is going on. This article sums it up nicely.......
    http://poolhelp.com/handouts/oB_Hydrati ... andout.pdf
    Your interpretation is plausible, though hydration issues usually show up relatively quickly, not after months. There isn't enough info here for me to have my own opinion if you are right or not. Metal stains are also a possibility, though they don't tend to be gray.
