Results 1 to 7 of 7
Thread: Quick Question on Chlorinators
    Can anyone tell me why i cant put cal hypo briquettes/tabs into a chlorinator that is meant for TCCA? I seem to find that Cal Hypo feeders sell for more.
    Is this to do with scaling or are there other issues involved?
    27,500gal IG plaster that needs recoating/painting!, Pentair Whisper-flo 1hp 2 speed, 48sf DE, Pentair Legend II pressure-side cleaner, BBB newbie
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Quick Question on Chlorinators
    Cal Hypo tablets dissolve much more easily than trichlor pucks. As such they can't use the same chlorinators.
    Don't add either product to a chlorinator that has been used for the other.
    Jul 2010
    England, UK
    156
    I think this is also to do with the fact that trichlor and cal hypo don't get along.
    I live a few miles from a pool chemical manufacturer, a few years back they had a big fire when two chemicals came together.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Mixing chlorine types is dangerous. I'm not sure exactly what bad chemical reactions would take place, but I wouldn't want to find out first-hand.
    Also, trichlor tabs dissolve nicely, staying hard and crunchy as they slowly dissolve. Cal-hypo tabs sort of turn into a mushy mess, so the feeder has to be designed differently to work with them.
    Dec 2009
    Central Massachusetts
    2,690
    The isocyanurates (stabilized chlorine) in the trichlor are acidic. When that acid hits the basic cal hypo;
    BOOM!
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Oh right, now i see. Cal Hypo feeders seem rather expensive.
    May 2009
    Dallas, TX
    782
    This thread: Mixing Chemicals illustrates the reaction nicely.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
