Results 1 to 13 of 13
Thread: Pump will not turn off or respond to CP3600
    Mar 2008
    Lafayette, LA
    108
    My main pool pump is no longer responding to my CP3600 control console. Does not respond to the spa remote either.
    The only way I can turn it off is the breaker.
    Hoping I can replace the faulty part, not the entire pump.
    I have verified the programming on the CP3600, and it will still control my Polaris...
    Let me know if you'd like more information, I'll do what I need to provide it.
    Thanks, Shell
    7x7 spa drains>16K IG, Gunite/Plaster, Compool 3600, Purex Triton Minimax Plus 350, Sand Filter, 8 Gal Liquidator
    Guest
    Re: Pump will not turn off or respond to CP3600
    Can you hear the relay tripping when you try to control it? Sometimes the relays go bad and no longer turn things on/off.
    Mar 2008
    Lafayette, LA
    108
    No sir, no click. Thanks. I'll see if I can't source another relay.
    Guest
    With the CP3600, you have one dedicated relay (for the circ pump) and 5 auxiliary relays (IIRC) for other items. If you have not used all the relays, try switching one of the unused ones out with the "bad" relay to see if that is actually the problem. If it is, then you can either put the bad relay in the unused spot or still buy a new relay to replace the one you stole!
    Mar 2008
    Lafayette, LA
    108
    You. Are. Awesome.
    Mar 2008
    Lafayette, LA
    108
    Well Bruce, you're still awesome, but all the relays are taken up with lights, valves, Polaris, etc.
    My local pool place, not so awesome. They can't say for sure whether they can get it, didn't want to cross reference it over the phone, didn't sound like they wanted to deal with it period. I had all the info ready to go. Disappointing.
    I'm going to try a local electrical supply but I remember having problems when I needed to replace the light relay last year since it is a Midtex product and they are outta business.
    If any of the vendors on here would like to help me out, the info is Midtex 187-26C2L1.
    Thanks.
    Guest
    Let me make a phone call........
    Guest
    I found 4 in stock at my local supplier. PM me if you would like me to get a price for you
    Apr 2010
    Buckeye, AZ 85326
    619
    I googled your part number and this was the first link. Looks like it might be helpfull. I'm sure Bruce will get you all set up though.
    http://www.electro-tech-online.com/data ... ource.html
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Mar 2008
    Lafayette, LA
    108
    Thanks Shane. Good to know for the future.
    Sending you a PM Bruce.
    Mar 2008
    Lafayette, LA
    108
    Just wanted to say thanks to Bruce, he hooked me up with the correct relay. It was a no hassle swap, everything works great now.
    Guest
    WooHoo I love a happy ending!
    Glad to hear it was a relatively easy solution. It's nice to win every once in a while, isn't it?
    Mar 2008
    Lafayette, LA
    108
    Yes it is. :nod:
