Results 1 to 11 of 11
Thread: Liquidator: in-line debris filter/screen
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    For some reason, when I installed the LQ a year ago, I installed the water in-take line (pressure) in the pump outflow and before filter. (I believe I read that would increase pressure)
    Because the water isnt filtered, I sometimes get small debris that pass through the pump filter, and are getting trapped in the float valve of water arriving into LQ. Twice, the float valve hasnt been able to close and the LQ has over flowed
    Does anyone have a part number for a small in line filter or debris screen that would catch the very small debris?
    I have made the 3/8" upgrade. (Last year before the upgrade, this overflow never happened - but i dont think there is a correlation)
    Guest
    Re: Liquidator: in-line debris filter/screen
    I used this one from an old Polaris dichlor feeder (see picture). I had a lot of very hard WS on mine tonight (ironically) and put the screen inside in some MA to clean it (looks like new now!). All of the WS would have ended up in my check valves and flow meter (I have the 3/8" upgrade also) before, and it is working just fine. As a note, I have never had mine overflow, as it is not below grade (we do have a few LQ's on vanishing edge pools with the upgrades that are below grade and have not overflowed either).
    I can see if I can get you a part number if you like. I'm not sure if they are sold separately or not though.
    22,553
    While you are correct about placement between the pump and filter will provide more pressure, there is no need for more pressure on the inlet side of the LQ. Even at 5cc/min (flow meter maxed out) a few inches of pressure on LQ inlet side will provide enough flow to keep the LQ full. Negative head pressure at the LQ outlet side is the critical parameter. You need enough negative head to get a flow of 5cc/min through the flow meter.
    By adding a filter to the LQ inlet you're doing basically the same thing as putting the LQ inlet on the clean side of the main filter.
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    Thanks to u both.
    Bama Rambler: I certainly should have placed the intake line AFTER the filter. I have an option to close the hole I have made where it is now, in the pipe leading TO teh filter and drill a second hole in the elbow AFTER the filter.
    My elbow (the only place available) is exactly like the one in the picture Simicrintz posted above
    QUESTION: is it okay to drill into the elbow? If so, i suspect the hole should be made not at the angle but just before it where there are two layers of PVC
    Simicrintz, I would appreciate a part number if possible. What you have is what I have been looking for, should I not drill a second hole in PVC. Many thanks
    (BTW, the reason for LQ overflowing is not its location to the pool. Its just that the valve is stuck open with a piece of debris.)
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    Simicrintz, I found the Polaris part on the internet. Price is way too high at $75 for the assembly. I will be able to find another one on the internet, now that I know what works. Thanks
    22,553
    It's safe to drill the elbow but if you can keep from having to that's the best plan.
    Do a search for inline strainer and you should be able to find something fairly cheap.
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    Bruce and Dave, what material is the screen on the strainer you use? Is it metal or plastic? I have found a seemingly fine strainer but the seller is recommending stainless steel over Polypropylene. (http://www.vacmotion.com/In-Line%20Strainers.htm)
    While the water flowing FROM the pump isnt a high chlorine content, I am still nervous about inserting any metal in the process
    Maybe I shouldn't be
    Thanks
    22,553
    Stainless steel doesn't do good in chlorine service. That whole chloride stress cracking thing. I'd go with the PP. It works great and there's no temperature concern in this service.
    Guest
    Mine is a metal mesh (maybe stainless, I would guess). It came with the dichlor feeder, which I had installed for about 2 years (and back about 6 years ago!). It looks like brand new still, but I'll have to watch it and see how it does in this application!
    22,553
    It maybe 400 series stainless or some other metal. It could be hastelloy but I'm not sure they'd make them out of that.
    Jun 2010
    San Antonio
    424
    What about the paint filters Miranda found? She posted about them in the other LQ thread. Would they work?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
