Results 1 to 13 of 13
Thread: A few quick newbie questions - need help
    Jul 2010
    Midland, MI
    12
    Ok - bare with me, I'm a 2 day pool owner. I've checked out pool school and am getting familiar with the whole pool chemistry - my TF-100 kit should be in tomorrow.
    First newbie question: when adding bleach/chlorine, do I pour this directly into the pool???
    How long do I have to wait before it's safe to use the pool once I've added the bleach/chlorine?
    And what about conditioner/CYA? On our skimmer basket, it says not to pour any chemicals into the skimmer - but the instructions on the conditioner says to pour slowly into the skimmer?
    I started pouring it in front of the skimmer, but a lot of the granules fell to the ground and I can see them spread about on the floor liner... is this okay/normal???
    That's it for now... and TIA!!!
    26.7k gal. 33' AG AquaLeader Influence, Hayword Power-Flo LX 1.5 HP pump, Hayword HeatPro 140k BTU,
    SwimPro Voyager filter, Hayword SP1091 Dyna-Skim Auto Skimmer
    Jul 2007
    Suwanee, GA
    528
    Re: A few quick newbie questions - need help
    Yes you can pour the chlorine directly into the pool. Just pour it slowly over one of the returns with the pump running. Depending out how much you add, it's probably ok to swim in about 30 minutes.
    I dump my CYA directly into the skimmer and it gets caught in the filter until it can dissolve. If you don't want to do that, you can put it in a sock and suspend it in front of a return and it will dissolve within a day or so. You don't want to let sit on your liner waiting for it to dissolve. You can vac that up and let the filter take care of it.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Welcome to TFP!!!!
    First newbie question: when adding bleach/chlorine, do I pour this directly into the pool??? Yes, in front of a return.
    How long do I have to wait before it's safe to use the pool once I've added the bleach/chlorine? Depends on how much you've added. For regular additions just to keep your levels up, I think they suggest 15 minutes, just to let it circulate. I've seen some say 30, some 1 hour. Maybe someone who really knows can answer that one better
    And what about conditioner/CYA? On our skimmer basket, it says not to pour any chemicals into the skimmer - but the instructions on the conditioner says to pour slowly into the skimmer? There are two ways to add CYA. You can hang it in front of a return in a sock, yes a sock that goes on your foot or stocking, and let it dissolve. The second way is to place it in the skimmer in a sock to dissolve. If you choose that way, you need to wait to backwash for a week to make sure it's all dissolved out of the filter.
    You will also need to wait to test the CYA for a week either way. But you knew that already since you've been reading the Pool School!
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
    Jul 2010
    Midland, MI
    12
    "You don't want to let sit on your liner waiting for it to dissolve."
    Uh oh, that's what it's doing right now - is it bad for the liner? What should I do?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Been there--------done that.....Now go vacuum your pool! It is acidic.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Vacume it into the filter, leave the filter running for 24-48 hours where it will dissolve. Don't backwash for several days or you'll lose what you added.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    If spilling some CYA on the liner is the biggest mistake you've made so far, you still get an A.
    It was an A+ for ordering your own test kit right at the start, not after you'd been pool-stored for a season
    Jul 2010
    Midland, MI
    12
    Ok, first of all, a BIG thanks to all you TFPers! If I need answers in an 'emergency' situation - I know right where to go to!!!
    I really didn't want to attempt vacuuming for the first time at 11pm at night (and after a Long Island Iced Tea ), but went ahead and assembled the vacuum by flashlight and managed to clean up all the visible CYA off the liner... and also some sand from the kids
    Also, tonight was the first time I added anything to the pool other than water and the 'pak' that came with the pool package... whoops! I had it running with the kids for two days without adding chlorine or CYA, which I added tonight... hopefully that won't be a problem???
    I only had 4lbs of CYA to add... I think I need 6lbs for my size pool - which also sits in direct sunlight. But I've also read that using the 'paks' keeps the CYA high, maybe it wont be so bad since the pool gets plenty of sun? I guess I'll have to wait a week and check the levels on that...
    I should have my TF-100 kit tomorrow - what are the first things I should check for in a 3 day old pool?
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by omster
    Do everything but CYA. Test that after a week.
    Be sure the pump's been on for a while - at least an hour - so the water is mixed well.
    Here's a tip: you don't have to do the test squatting next to the pool. Get a sample in some sort of cup, carry it over to a comfy spot (avoid somewhere where a spill will stain the carpet ) and do your tests there. Use the pH/ Chlorine block first. Then run the FAS-DPD test. that way you'll get a feel for the colors. Sunlight is best, with a white background. Even concrete isn't white enough - it will skew the results. Then TA and CH. Expect those to take a while, especially CH, if you have hard water in your area. It takes a lot of mixing. You'll be switching hands after a while when you're swirling. That's why I bought a speedstir.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Quote Originally Posted by Richard320
    Awesome tip!, I'm gonna have to try that out, sound like it would be much more comfortable than going back and forth?
    How do you get the water from your sample to your testing vials? Do you just pour it in, or do you have some sort of syringe/dropper?
    When I test my aquarium water all of my test vials are 5ml. I just bought a 5ml syringe from the drugstore. The kind that you buy to dose small children, they usually come with a rubber stopper to put on top of a cough syrup bottle etc... Ive been tempted to look for one that can do 10 or 25ml for testing this stuff.
    For the FAS-DPD test, I usually use the back of the sticker since it white. (to the OP the TF-100 kit has a vial that has a sticker that reads "Chlorine Only")
    Hope those tips help.
    EDIT: out of fear of looking a wierdo, I found a link to what I was talking about, something like this http://www.walgreens.com/store/catal...001629-product
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I use something like this:
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    My local pool stores have been very happy to give me flip top squirt bottles to bring water samples to them for free testing. I've been a little slow to bring them back for testing however.
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by Puffin
    I have a plastic 2 cup measuring cup with a pour spout. I just pour it in. Since I do my testing on the patio table, if I overfill, it's no problem to flip some out in the general direction of the planters.
