Thread: pool slide - leak repair
    Alamo, CA
    7
    Type of Slide: Interfab X-Stream
    Problem: leaking at all 3 joints - 3 slide segments plus the platform at the top of the steps
    Clean fix: Replace gaskets at $28 per gasket, total $84
    Cheap (temporary?) fix: caulk the joints - this was attempted by the previous owner and the caulking has deteriorated.
    Suggestions?
    (1) Pool size - I think about 35,000 gals? Pool is 20' x 40'
    (2) Sand filter
    (3) AG
    (4) Vinyl
    (5) Pump: 1.5 hp Hayward super pump Filter: Hayward S240 (I think 65 cfm)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: pool slide - leak repair
    you can try to disassemble the slide and put jacks lube on the gaskets and reassemble them. Other than replacing the gaskets, 100 % silicone might work at the joints.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Alamo, CA
    7
    X-PertPool,
    I'll check out your suggestion. Thanks.
    (2) Sand filter
    (3) AG
    (4) Vinyl
