Results 1 to 19 of 19
Thread: Help ID'ing PVC pipes.
    Jul 2010
    Las Vegas, NV
    15
    Brand new to the forum, first day looking & first post, and I have a question no one I know personally has the answer to, even Google. The house is in Las Vegas and I don't know measurements or anything yet as we only have an offer in on the house and no answer yet.
    I'm looking at purchasing a larger house that has a pool, Pebble Tec I believe, and it has 5 PVC pipes (2 have same diameter & 3 others same diameter) coming out of the back area vertically closest to the rear wall that I can't identify. My first thought was tiki torch holders, kinda close together, or possibly to go to a waterfall type of thing but doesn't seem likely. If anybody can tell me what these do or the reason they're there I'd be really grateful. Thanks!
    Along right side of picture.
    The mystery PVC hole. There are 5 of these.
    Towards back wall.
    Approx. 18'X24' Pebble Tec free form shape.
    Guest
    Re: Help ID'ing PVC pipes.
    How many pumps are there? That may have been for a water feature that used urns or pots of some sort, and they bubbled up. Hard to tell without seeing the equipment area also.
    It looks like 4 pipes at that "pad" area. The one in the pool is probably a "frothy bubbler".
    Whereabouts are you in Vegas? I have a friend out there that may be able to stop by and take a look for you.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by simicrintz
    Or maybe an umbrella sleeve? Looks like a great pool!
    Jul 2010
    Las Vegas, NV
    15
    There are 4 on the pad area and one to the left. I'd guess the inner diameter is approx 1.5" on the PVC pipes. I'm a pool newbie and I took a look and it only appeared to have 1 pump. I'm hoping to hear back today if my offer on the house got accepted and if it did I'll be headed over to take more pictures to post of the rest of the set up. The house is located in Southern Highlands on the south side of town.
    Mar 2009
    Huntsville, AL
    156
    If you get the house take a flashlight with you and look down inside the pipes. It might be a useful clue if they go into an elbow or if they dead end into the dirt.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Based on the shape of the pool I would guess it was some sort of water feature, water fall, or maybe even a spill over hot tub. I suspect it was removed to allow access to the back corner of the lot without having to go through the pool. Based on number of pipes I would guess hot tub, but that certainly seems like it was not much space for one, then again it is a wall to wall pool.
    Ike
    Jul 2010
    Las Vegas, NV
    15
    Quote Originally Posted by Isaac-1
    Ike
    I thought it might be a water feature as well but there's definitely not enough room for any sort of hot tub. Still waiting to hear from realtor... tick tick tick... Thanks for the warm welcome and everyone's help thus far.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    those are the discharge tubes for the fireworks mortars, check for a timer as they probably go off nightly. just kidding.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2010
    Las Vegas, NV
    15
    Quote Originally Posted by X-PertPool
    Too many weeds in the open field behind it otherwise it'd be a great idea! Hoping to hear something today...
    Jul 2010
    Las Vegas, NV
    15
    Good news is they accepted our offer on the house today! I'll be going over to the house to take a lot more pictures of the mystery PVC piping and also the pump station so that hopefully I can get further advice on how to proceed from here.
    Also, the pool looks clear and the water looks nice but after doing lots of reading here I think the consensus is to run with the BBB method. The house won't be ours for at least 30 days due to escrow but I'd like to get the pool up to par before we move in. Would it be advisable to just start with the TF-100 or simply use a Wal-Mart brand or pool store guy for now? Thanks!
    22,551
    I'd definitely start it off with the TF-100.
    You'll be way ahead of the game to get a full set of test results before you move in.
    Jun 2010
    Glendale, CA
    513
    Congrats on the house.
    BBB is definitely the way to go - especially in Vegas since you'll be keeping the pool open all year. I couldn't recommend the TF-100 more highly. The cheaper test kits dont have an accurate Chlorine Test (FAS-DPD). Judging by that floater in the pool your CYA is high and the FAS-DPD test is essential. Keep up with the pool school - read the Chem section, let it sink in, read it again - and it'll all feel less daunting. Knowledge is power when it comes to pools.
    I wouldn't do the pool store thing - I learned the hard way. Really - a good test kit and knowing how to use it saves me a ton of $.
    If you dont have access to the house for the next 30 days make sure that the pool service is still coming. Else try to stop by once a week and throw in some pucks in that floater if nothing else. When we took possession of our house the pool had gone from "nice" to "pond". If your house is in any financial stress the maintenance stops the moment you sign the paperwork.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Jul 2010
    Las Vegas, NV
    15
    Quote Originally Posted by lightingguy
    Thanks for the advice. The pool school and all the different tests & chemicals is a bit daunting at first but I'm sure we'll work our way through it with the great help on this board. We have access to the house and backyard during this time but I won't be monitoring it that closely due to proximity so I may just use pucks for the next month or so and then make the switch to BBB.
    Guest
    Let me know if you want me to get you in touch with my buddy over there. He works for the company that probably finished that pool, and he might be able to provide some insight.
    I noticed your avatar is "missing". I didn't think that was gonna last real long (this is a family site!). Stick with us and you'll have the nicest pool on the block!
    Guest
    Those might be for Tiki Torches...
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,063
    Congrats on your new pool and house I am thinking that I would be more excited about your pool than your house . I know that because we spend 90% of our time in our backyard
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jul 2010
    Las Vegas, NV
    15
    Thanks for the offer I'd really appreciate it when you get the time. We went back over last night and I took a flash light. There are definitely elbows in the bottom of those pipes and they look like they all meet up underneath. I also found what might be a valve possibly inline with them but I didn't feel like digging up a bunch of rocks in the middle of the night.
    Jul 2010
    Las Vegas, NV
    15
    Quote Originally Posted by salp
    Elbow and T off in the bottom so I'm leaning away from this.
    Jul 2010
    Las Vegas, NV
    15
    Quote Originally Posted by Brentr
    Thanks and us too.
    Here's a picture of the filter & pumping station. Weird thing was those 2 vertical pipes went out the front wall and stopped. It appears they might've been trying to set up solar on the roof or something??? I cut & capped those due to the VA inspectors coming and not wanting to deal with them on the subject.
