Thread: Heat pumps - do you have to have a solar cover?
    We installed a new pool this summer. It's been brutally hot and my water averages about 88 degrees so far. No need to use my Thermaflo yet. Someone told me that heat pumps require you to get a solar cover also. My PB never said that to me. I have a funky free form pool so a cover would be a challenge and also I don't like them. Any thoughts of if this is true? I had a gas option as my house is heated with propane and this will make me angry if so.
    24,000 gal free form with slide feature
    3.5ft to 5.5ft Sport Pool
    Midnight Blue Diamond Brite
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Clean and Clear Cartridge
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Heat pumps - do you have to have a solar cover?
    Your electrical usage will be higher and your maximum potential temperature rise will be lower without a cover, but the heat pump will still work without one.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Solar covers hold in heat. How the heat is generated (gas or HP) makes no difference. Without one, you will lose heat very quickly in the cooler months at the beginning/end of the season. You can keep your pool warm without one, but it will cost a lot more.
    Vero Beach, FL
    462
    Its required on all new installs here in my county in Florida. Might be true for the entire state. Anyway, I had a small electric heater put in for my overflow spa and the PB had to supply a solar cover for the spa. It had to be there during inspection.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by Melt In The Sun
    What Melt said
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
