Results 1 to 9 of 9
Thread: pH won't lower
    Lehigh Valley, Pennsylvania
    71
    pH won't lower
    I am trying to lower my pH but do not seem to be making any progress. Test results as follows:
    FC - 4.0
    CC - 0
    CYA - 40ish
    TA -115-120
    PH - 7.9
    Trying to get the pH down to around 7.6 or so. Per the pool calculator I should add 21 oz. muriatic acid. I have added about 20 oz. so far but it has not seemed to drop at all. Granted it is a color test, so subjective, but I have not really noticed a change in color of the dye test. I am somewhat apprehensive about adding too much acid to the pool so before going further dumping more in, I thought I would get some input. Am I missing something or should I keep going with the acid?
    Rob
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    Re: pH won't lower
    I get 35 oz, not 21 oz. Did you remember to enter your current TA level when calculating the PH change?
    Another thing to watch out for is lower strength muriatic acid. Some places sell half strength, or various other strengths, instead of the full 31.45% that the Pool Calculator defaults to.
    Feb 2008
    Denton, TX
    5,061
    Re: pH won't lower
    With a TA of 120, using the Pool Calculator, I get 24 oz. of 31.45% HCl- to lower the pH from 7.9 to 7.6.
    Are you also certain about your pool volume in gallons?
    71
    Re: pH won't lower
    I agree with 257's # of 24 oz. I am using the 31% acid. As stated, I'm at 20 and really am not seeing a change. TA is somewhat on the high side, is that having any affect? As far as the gallons, don't have an exact number but I'm sure I'm within 1,000 gallons.
    Re: pH won't lower
    I calculated lowering the PH to 7.5, which would be the normally recommended target level, but isn't what you said. And you are right, 20 oz should have been enough to show a visible change in PH.
    The PH could well have gone up since you added the acid. I would add another 20 oz of acid, run the pump for an hour, and test the PH again.
    MyBad's Avatar
    Feb 2010
    AZ
    60
    Re: pH won't lower
    Maybe you have 15% muratic acid, I went to Home Depot and bought a box, just like always. Calculated the amount with pool calculator, added the acid and nothing. So I did it again, and the pH dropped very little....anyway took a look at the box and sure enough it was half the strength they normally have!!?? Didn't even notice when I was buying it.
    MB
    Looking to build a new POOL
    Feb 2008
    Denton, TX
    5,061
    Re: pH won't lower
    This is actually one reason why I like the acid demand test when it comes to correcting pH. If I can add a drop of acid demand reagent and make the color improve to something I like better, then I just think that it is that much easier to dose it and fix it.
    71
    Re: pH won't lower
    What is the acid demand test?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: pH won't lower
    It is included in the K-2006 kit (among others). It basically is a measure of how much acid is needed to "move" the pH by a certain amount. Once you measure pH you add drops of the Acid Demand reagent to the pH sample until the color matches your target pH. Then you look up in a table how much acid is needed. There is also a Base Demand you can use if your pH is low.
    I use the pool calculator is lieu of the Acid Demand test, which is accurate enough for me for moderate pH changes.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
