Thread: How do I replace deck boards
    Jun 2010
    San Antonio
    424
    Not sure this is the right place for this question. I have some deck boards that have curled up at the end near the pool. I need to replace the curled up part. (See pic.) I also have boards I have to remove at least part of the board (need about 2 inch clearance to remove cap and only have 1/2 inch) in order to remove the top rail connector caps. (see pic) I cannot remove the entire board because another deck is built over part of the board covering up the screws on that end. How do you suggest I deal with this? There are two 2X6 joists supporting the deck boards about one foot from the end (can be seen in pic) One thought I had was to take a reciprocating saw and cut off the end of the deck board somewhere around the joists and then replace the cut off damaged portion. If I do that where should I cut? Are there better ways to deal with this?
    As always thanks in advance
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: How do I replace deck boards
    Cut it off somewhere between the two joists. Add another 2x6 between them to nail too?
    Jun 2010
    San Antonio
    424
    How do I add the other 2X6? Do I add it parallel to one of the joists or perpendicular between them?
    Larry in Texas
    Jun 2010
    San Antonio
    424
    Bump
    Larry in Texas
    parallel to joist right up against the joist for a place to nail the new board down.
    24' 52" Above Ground
    BBB
    LOVE TFP
    TF Test kits, Pool School, Pool Calculator
    Jun 2010
    San Antonio
    424
    Thanks
    Larry in Texas
