Results 1 to 7 of 7
Thread: new pool...
    Jul 2010
    southern indiana
    10
    new pool...
    Fc 3.2
    Ph 7.6
    Ta 160
    Cya 20
    I had put some liquid stabilizer when I filled the pool...
    Tonight...
    I put a couple pounds of stabilizer in a sock and hung in front of return.
    I added 77oz of 10% bleach.
    What cha think?
    Mike
    22,000 gallons, cartridge filter, 1.5 hp hayward pump
    ag, vinyl
    30,431
    Re: new pool...
    Tell us what your water looks like.
    Jul 2010
    southern indiana
    10
    Re: new pool...
    We had 4 teenagers in it today...
    It looks clear to me..
    Mike
    ag, vinyl
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: new pool...
    Numbers look good - is your FC holding? Any issues that prompt the question or do you just want some reassurance?
    Jul 2010
    southern indiana
    10
    Re: new pool...
    I have not done overnight Fc check yet....
    I was wondering about the TA level?
    thank you
    Mike
    Mike
    ag, vinyl
    Feb 2008
    Denton, TX
    5,061
    Re: new pool...
    How often are you having to add acid to your pool? If your pool needs acid fairly frequently to keep the pH from climbing too high, then you should probably get that TA down. Normal TA is usually between 80 and 120 ppm but a little above or below isn't always a bad thing.
    Re: new pool...
    TA is something that will eventually lower on its own as you add muriatic acid (MA) to control rising pH. You don't have to work at lowering it unless you want to get it under control faster. pH looks good now, let's see how long it takes to get to 7.8 or so. Then add MA to lower to 7.2 and watch it again. If you go lower, like to 7.0, it is good to aerate to hasten the rise in pH.
