Thread: Product recommendation for sealant or epoxy vinyl inground
    Jun 2007
    Boise Idaho
    58
    I have an in-ground vinyl liner pool that was build 3 years ago. All of the caulking that was used around the steps, ladder, and skimmers is coming off. What is the best product to reseal?
    Should I drop the water level to seal these or is there a product that works well under water. I have a large amount to seal.
    __________________________________________
    18x36 inground, sand filter, sta-rite sr400 ng heater
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Product recommendation for sealant or epoxy vinyl inground
    There shouldn't be caulking there. Just gaskets
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jun 2007
    Boise Idaho
    58
    There are gaskets there as well, but they also put white caulking that is coming off. Do I just scrap it off and hope it doesn't leak? Or clean and replace the caulking?
    Dec 2009
    Central Massachusetts
    2,690
    Post some pictures so we can see. Like pool-x-pert said, there should be no caulking. Where is the caulking around the ladder? The ladder should just lift out of the fittings in the deck.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
