Thread: Lightening
    Jun 2008
    Port Neches, Tx.
    144
    Lightening
    Thought our Aquatrol got fried yesterday by a very close lightening strike.
    Went outside after big hit and the pump wasn't running on the pool. I went and looked at the panel and there was no power. I unplugged the pump from the panel and plugged it into the receptacle and started the pump. I then unplugged the Aquatrol and took off the cover to check the fuse, the fuse was fine. I put the fuse back in and plugged the unit back into the receptacle and it powered up, cut the pump off, plugged it back into the unit and all is good.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Lightening
    That is scarey stuff because the costs add up while you scramble to get something else going to take care of the pool. We have an insurance policy on our pool. covers damage from lightening strikes, tornadoes, etc. We have had lightening hit close by and it kicked out the GFI - reset and its all good again, but just in case....
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jun 2008
    Port Neches, Tx.
    144
    Re: Lightening
    Happened again today, same results.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    22,544
    Re: Lightening
    Sounds like it's time for a whole house lightning protector. They're kind of expensive and require proper installation but well worth the money in high probability areas.
    Jun 2008
    Port Neches, Tx.
    144
    Re: Lightening
    I think I'll take my chances and see what happens. Been having storms right on top of us last couple of days, surprised there are no trees affected.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
