Results 1 to 8 of 8
Thread: Need help with plumbing
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Woke up to find a thin stream of water shooting 10 feet up in the air. The flex hose between the pump and the filter had developed a pinhole leak. After removing the offending hose and scouring the local hardware and pool stores, I finally found enough pieces to make repairs. I have two elbows with one threaded end and 1 slip end, 1 union with two slip ends, 1 elbow with 2 slip ends, and spa flex pipe cut to fit. I dry fit the pieces together and opened the valve to the pump so gravity would start to fill the filter. Of course, there were leaks at every joint. What do I need to do to prevent leaks when I glue the pieces together? Are there any tips or techniques for making the threaded joints leak free?
    Love TFP? Become a
    TFP Supporter!
    30,414
    Re: Need help with plumbing
    Hey, zea,
    PVC glue joints are fairly simple...
    1. make sure both sides are completely dry
    2. Prime carefully and thoroughly (I personally don't like the purple primer aesthetically)
    3. The glue can set up VERY quickly in this hot weather.....be prepared. Using a little extra glue can be helpful to retard the setting time but it makes a sloppy-looking joint. Sometimes you can wipe it down with a rag and improve it.
    4. It usually helps to apply glue to one side, then the other, and lastly go back to the first side and give it a quick "refresh" application if you move fast.
    I would suggest pipe joint compound (HD/Lowe's/hardware store) for the threaded joints. You can be really slow and picky with this and get compound down into both sides of the joint and then wipe of the excess. Some folks use Teflon Tape but on anything bigger than 1", I like the joint compound a little better.
    (Much duplication with duraleigh, but some new information)
    Threaded joints can be a little tricky. You need to use a teflon based thread compound and you need to tighten them correctly. If you have never done it before it sometimes takes a couple of tries.
    Glued joints are easier. Make sure you use the correct primer and cement and that both the primer and cement are applied to the entire surface of the joint on both sides. Apply primer to everything, wait a moment, apply cement to everything. Push the joint together and then twist the two pieces to spread the glue throughout the joint. Be sure to hold the pipe together until it sets (typically 10 or 15 seconds) or the pieces will push apart from each other.
    Jul 2009
    Houston, Texas
    9,379
    Thank you, gentlemen! I am almost finished except 1 small problem... the pipes slide further into the fittings with the glue than they did with the dry fit, so one side is 2" too short.
    I even pounded them with a rubber mallet when I did the dry fit!
    Oh, well tomorrow I shall again brave the heat and mosquitoes and try and get this finished!
    Thanks again guys!
    Love TFP? Become a
    TFP Supporter!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by zea3
    Thank you, gentlemen! I am almost finished except 1 small problem... the pipes slide further into the fittings with the glue than they did with the dry fit, so one side is 2" too short. !
    That will burn you every time!
    I measure everything now, and still occasionally end up crooked
    Mar 2007
    Coastalish 'down easter'
    4,160
    Zea, one other thing, read the can of glue you use and don't flood the pipe until you've reached the minimum set time (usually 10 - 30 minutes). If the glue hasn't set or cured enough, the water pressure will wreck the bond
    BTW - dry fitting the flex pipe is an exercise in futility, I just hold the pipe up to the fittings (knowing where the 'stops' are) mark the end I'm going to cut with my thumb, then add 2 more ribs for safety's sake.
    Luv& Luk
    -Ted
    Jul 2009
    Houston, Texas
    9,379
    Gee Ted, why didn't you speak up yesterday!
    I think the glue is good and set now. When I tried to pull the too short piece out it was already set firm! Today I will get the (hopefully) last 2 pieces set.
    I will let it sit a few hours before I test it. Since it ate up most of my day yesterday I have a lot to do today, so it has plenty of time to cure.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    4,160
    It might have something to do with my retrowling the sand in a 24' AG all day and setting the liner (for one of my wife's friends)
    I hope it sets (sits) well this time
    10 - 19 ROCKS!
    Luv& Luk
    -Ted
