Thread: HOW LONG TO WAIT AFTER CITRIC ACID TREATMENT BEFORE SWIMMING
    Nov 2009
    MS Gulf Coast- Katrina Survivor - BP Hater!
    55
    If I treat with 3-4 lbs of citric acid, how long before I can swim. I know the PH will be in the high 6's so will it be a problem? I have a party later today and wanted to "dress up" my slightly stained pool. I use citric so I'm familiar with the results just never swam the day of treatment.
    Thanks
    15,000 gal Sun Fiberglass, Glass/Lexan/Aluminum Enclosed Room, 1.5 hp Pentair Whisperflow Pump, Triton 100- 600# Sand Filter, Heat Siphon Heat Pump, 3 Dbl. Seats w/8 Jets, Waterfall, 8' Interfab Slide, Pentair SAm Spectrum Amerlite Pool Light, Stenner MHP5 Chlorine Pump, Kreepy Krauly Vacuum, Bleach, 50 ppm Borates, TF 100 Test Kit
    Re: HOW LONG TO WAIT AFTER CITRIC ACID TREATMENT BEFORE SWIMMING
    Swimming right away isn't a good idea, or in this situation, doing the treatment isn't a good idea. PH below 7.2 tends to cause eyes to sting and some people will have skin irritation/itching. Also, citric acid only works when you/it eliminates all of the chlorine, and swimming without any chlorine is never a good idea. If you start the treatment and then add chlorine too soon (first or second day) the stains will usually come right back.
    Nov 2009
    55
    Thanks for the quick response Jason. Didn't think it was a good idea.
