Thread: Numbers- do I need to add anything?
    new2pools's Avatar
    Hampton Roads/Virginia
    180
    FC-6.0
    CC- .5
    CYA- 20
    TA - 120
    CH-90
    PH - 7.6
    Pool water is crystal clear.
    Thanks!!
    27' Round AGP, 17200 GAL, 2 HP/2 SPD Pump/Cartridge Filter.......BBB!
    30,432
    Re: Numbers- do I need to add anything?
    Your teswt results look fine except for CYA.
    20ppm is a little low and, while it doesn't hurt anything, causes you to use a lot of chlorine.
    I would suggest increasing CYA to 40 or so if you live in the North and perhaps as much as 60 if you live in the very deep South.
    new2pools's Avatar
    180
    Thank you!
