Thread: Pain in the rear or golden opportunity?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Last night I added bleach and let the pump run. This morning I find a pinhole leak in the flex hose between the pump and the filter. I am considering adding a SWG in the future, could it be placed between the pump and the filter? If so I could go ahead and put the unions in there now instead of redoing it when I end up getting a SWG. The space between the pump and filter is about 1.5 to 2 feet at most.
    Love TFP? Become a
    TFP Supporter!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pain in the rear or golden opportunity?
    If you have flew hose, it has been my experience that once you start getting pinholes, it will soon be time to replace the whole thing as you will get more and more and end up with nothing but patches.
    Jul 2009
    Houston, Texas
    9,377
    This is the only spot with flex. Pool to pump and filter to pool are hard piped with valves. I don't know why they used flex between filter and pump.
    Love TFP? Become a
    TFP Supporter!
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    They probably used flex to cut down on vibration and any resonance noise caused by the pump. JMO
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    22,543
    I'm not sure why they use it either but mine has it too. Everything else is hard piped.
    The SWCG is supposed to go after the filter. That keeps debris from getting trapped in the cell. It gets caught in the filter instead.
