Thread: bleach smell?
    bleach smell?
    Does bleach have more odor that dichlor? I was shocking with the dichlor packets that came with the pool and switched to bleach when I used those up. I notice the bleach smell a lot more.
    WilBar Escalade 18x40 Oval AGP
    7' Hopper Style Deep End, 27K gallons
    Vinyl Unibead Liner
    Sand Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: bleach smell?
    This is just a guess, but it seems to me that fumes from dichlor an be intense, ever caught a whiff from an open tub of dichlor or trichlor? Whereas bleach tends to have a milder "bleach" smell, I suspect this has to do with the fact one is a liquid and the other a powder.
    Ike
    Re: bleach smell?
    If you are smelling the straight chemicals, what Isaac-1 said is exactly right. However, if you are smelling the pool after adding chemicals, then it probably doesn't have anything to do with which kind of chlorine you are using. Smelling chlorine from the pool usually means your chemicals are out of balance.
    Jan 2010
    Randleman,NC
    620
    Re: bleach smell?
    When I started up this year had a little odor for the first week.But went away..No smell now..Just clear,clear water!!!
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
