Results 1 to 13 of 13
Thread: Concrete in wedding cake steps? Bad idea?
    Jan 2008
    Northeast Florida
    161
    Currently my wedding cake steps weight compartments are filled with pea gravel and water. I am considering filling them with quickcrete or portland cement to make them a bit heavier, and to reduce potential for spillage and algae growth inside compartments. Good idea? Bad Idea? If I do this, should I mix it first, or put it in dry and add water as I go?
    Link is to a site with density info http://www.simetric.co.uk/si_materials.htm
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    South Central NJ
    3,192
    Re: Concrete in wedding cake steps? Bad idea?
    Portland needs something to bind too as an aggregate. I think Ready-Mix would be better. The steps will need to be removed first so the cement can harden. Depending on the compartment, you will want a way to remove the cast concrete weights you're making so the steps can be removed when required. Sometimes a wax coating, like paraffin, or silicone spray coating will do it.
    Scott
    Owner of - PoolGuyNJ LLC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Wouldn't it be simpler to just find some hefty river rocks to put in instead of the gravel? Or if there's room, ceramic tiles? Those things are heavy. You might be able to find some hideous ones real cheap at a tile store on the closeout table.
    Jan 2010
    Randleman,NC
    620
    Put Brick's in it....I had a set of step's onetime I had some brick laying around it worked and after 8 yrs of use I throw it away an the brick still looked good!!!
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jun 2010
    San Antonio
    424
    Another way to make it removable is to find plastic containers that will fit the shape and then fill with cement. That is the way we make anchors for buoys. We put cement inside gallon milk bottles. I would go for rocks or bricks. Should OP be concerned about the water chemistry with adding cement, bricks, or rocks ?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    22,550
    Actually a better option would be sand and water. Sand is heavier than pea gravel per volume and will pack together better too. Water is needed to displace the bouyant air in the spaces. We used to add calcium carbonate to the water in tractor tires to make the water heavy so you could do the same thing if you wanted to. That way if it ever ruptures all you'd add to your water is a little sand and some calcium.
    24' x 52" Round AGP. 2hp/Ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jun 2010
    Toms River, NJ
    80
    I made weights for my stairs using 3" pvc and sand. Cut the pvc into 2' lengths, put an end cap on, fillled it with sand and water, put the other end cap on. I then tied it to the back of my stairs with nylon cable ties. Works pretty well and the whole thing is plastic so its easy to clean at the start of the season. Perhaps you could play with the pipe sizes and lengths to fit your ballast box.
    18'x24' (10,000 gal) above ground pool, 19" Proline sand filter (45 GPM), Jacuzzi 1.5 HP 2 speed pump
    Jan 2008
    Northeast Florida
    161
    My steps do not have a ballast box or place to put bricks or boulders. They have hollow compartments with a small hole for filling (pea gravel is recommended) They are bolted to the underside and are removable, but difficult to do under water. I'm just trying to decide what to fill them with. See link:
    http://www.royalswimmingpools.com/Lumi- ... ctions.pdf
    Richard320's Avatar
    Jan 2010
    19,004
    The picture makes it much easier. Fill it up with sand then glue it closed. Sand stays in, algae stays out.
    Wait... what are they made out of? PVC is easy to glue. Polypropylene and polyethylene aren't.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Have a look at our step weights, it may give you some ideas. The process we describe on our Website uses sand but we changed to QuickCrete this season. Using step weights such as these allows you to put the steps in or pull them out by yourself—a one person job, if necessary, and you don't have to get in the pool to do it.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Jan 2008
    Northeast Florida
    161
    Quote Originally Posted by Richard320
    I wish I knew the difference.....LOL, it is a translucent slightly flexible plastic...the same stuff my kayak is made of if that makes any sense
    Jan 2008
    Northeast Florida
    161
    Quote Originally Posted by AnnaK
    I don't have a shelf or space under the bottom step on which to rest weights. The bottom is wide open. The ballast compartments bolt to the inside of the steps and removing them is not convenient, because you need a screwdriver on the outside and a wrench on the underside. Installing the ballast boxes is even harder in the pool, since there are holes to line up underwater. Scuba gear would help. I don't need to winterize, so I will just be leaving them in. Just trying to decide if i'd have less air/algae potential if I used quickcrete instead of sand/water.
    Titus's Avatar
    Jun 2010
    Nevada, TX
    47
    When installing my wedding cake steps, i went to Home Depot and bought 2 5 gallon buckets with lids, 2 bags of quickcrete, and a bag of pea gravel. Each bag got a bag of quickcrete and water, mixed a little runny, and then I stirred in pea gravel until I was to the top of the bucket. Waited about 3 hours, snapped the tops on, and lowered them into the pool. From in the watter, I placed them in the steps, and a slowly maneuvered them into place. They have been like that for over 2 months now. The steps have not moved and the chemistry is unaffected.
    32x16 DoughBoy Autumn Breeze with partial bury, 7' deep end, happy bottom, and Access wedding cake steps.
    Pentair DE FNS Plus 48 with Pentair Challenger 1.5 hp.
    Order placed 6/13/10. Excavation started 6/15. First swim 6/18. Two thumbs up for DoughBoy, Crown Pools, and Mendez Pools and Decks.
