Results 1 to 7 of 7
Thread: Just got my Intex Sand Filter
    And All I can say is WOW!!! They should of packaged these with it. Very easy to set up as well. Now here is my ? I have the Intex Swg as well and by the pool school you should run your pump for 8hrs with swg system. In the manual it says I should run it 5 hours for my pool. Which one should I do?
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    May 2009
    Jasper, TN
    249
    Re: Just got my Intex Sand Filter
    Quote Originally Posted by pitmanr2003
    You run until you don't need it.
    Run it a few hours, check your FC. If it's not high enough add another hour or two to the swg run time. if FC is too high, knock off an hour of run time.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    no not that my pump. in the pool school it says to run atleast 8hrs when you have a salt system. I dont want to run it 8hrs if i dont have to. in the manual for the intex sand filter it says 2hrs with out swg and 5hrs with swg.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    8 hours is generic advice that usually applies, but isn't true every single time. If you have a relatively large pump, compared to your pool size, and also a relatively large SWG compared to your pool size, there is no need to run the pump for 8 hours a day.
    The Intex instructions are also generic. The larger the pool, the longer you need to run the pump. Intex makes pools over a wide range of sizes. Their suggested run time covers a fairly large range of pool sizes, but not every possible pool. Small pools will be fine with a shorter run time, larger pools will usually require a longer run time.
    This was the run time it said for my exact pool. It had a list for all the pool sizes in manual. I run swg 4 hrs and it does great. I ran pump 8 hrs and all looks good
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    What kind of pump/filter did you have before? And when you say wow, are you talking about more circulation/better filtration? After visiting the pool place today (Still have cloudy water), I'm thinking about possibly switching to a sand filter.
    Keith
    Intex 15' x 48" AGP (5300 gallons)
    Intex 2,100-Gallon Sand Filter Pump
    Central Mo
    i had the 1500 that came with it. I never had a issue with my water looking bad. I guess I got one of the good intex cartridge filters.. I cleaned my filter off with water hose every two days or so. Only used two so far. What I mean by wow is how much more suction and pressure. I would say its well over twice as strong.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
