Results 1 to 15 of 15
Thread: Lowering PH before shocking
    Over in this topic:
    Quote Originally Posted by chem geek
    If one is going to shock at high levels using a hypochlorite source of chlorine (bleach, chlorinating liquid, Cal-Hypo, lithium hypochlorite), then one should lower the pH first before doing so. Adding chlorine raises the pH. Though it will come back down when the FC level drops, you don't want the pH to get too high because it can precipitate metals that can cause staining, can cause cloudiness from over-saturation of calcium carbonate, and at much higher pH the active chlorine level goes down significantly.
    The following assumes a TA of 80 and CYA of 80 and adding the amount of chlorine indicated at different starting pH. I indicate in red the starting pH that would be reasonable to keep the pH reasonably low.
    10 ppm FC: 7.5 to 8.00 (active chlorine cut by 13%); 7.3 to 7.60; 7.2 to 7.43; 7.1 to 7.27; 7.0 to 7.13
    15 ppm FC: 7.5 to 8.37 (active chlorine cut by 19%); 7.3 to 7.86; 7.2 to 7.61; 7.1 to 7.40; 7.0 to 7.22
    20 ppm FC: 7.5 to 8.63 (active chlorine cut by 25%); 7.3 to 8.21; 7.2 to 7.88; 7.1 to 7.58; 7.0 to 7.34
    25 ppm FC; 7.5 to 8.80 (active chlorine cut by 32%); 7.3 to 8.50; 7.2 to 8.23; 7.1 to 7.85; 7.0 to 7.51
    30 ppm FC; 7.5 to 8.91 (active chlorine cut by 38%); 7.3 to 8.68; 7.2 to 8.49; 7.1 to 8.18; 7.0 to 7.75
    35 ppm FC; 7.5 to 9.00 (active chlorine cut by 45%); 7.3 to 8.81; 7.2 to 8.66; 7.1 to 8.44; 7.0 to 8.06; 6.9 to 7.59
    If you have 50 ppm Borates in the water, then you don't have to lower the initial pH by as much:
    10 ppm FC: 7.5 to 7.71 (active chlorine cut by 7%); 7.3 to 7.49; 7.2 to 7.37; 7.1 to 7.25; 7.0 to 7.12
    15 ppm FC: 7.5 to 7.81 (active chlorine cut by 9%); 7.3 to 7.60; 7.2 to 7.47; 7.1 to 7.34; 7.0 to 7.20
    20 ppm FC: 7.5 to 7.91 (active chlorine cut by 11%); 7.3 to 7.71; 7.2 to 7.58; 7.1 to 7.44; 7.0 to 7.28
    25 ppm FC; 7.5 to 7.99 (active chlorine cut by 12%); 7.3 to 7.81; 7.2 to 7.69; 7.1 to 7.55; 7.0 to 7.38
    30 ppm FC; 7.5 to 8.06 (active chlorine cut by 13%); 7.3 to 7.91; 7.2 to 7.80; 7.1 to 7.66; 7.0 to 7.50
    35 ppm FC; 7.5 to 8.13 (active chlorine cut by 15%); 7.3 to 7.99; 7.2 to 7.89; 7.1 to 7.77; 7.0 to 7.61; 6.9 to 7.42
    The bottom line is that when shocking by adding more than 10 ppm FC, one should lower the pH to at least 7.2 first. If shocking by adding more than 20 ppm FC, lower the pH to 7.0 first. You need to lower the pH before you add the chlorine so that you will be able to measure the pH accurately since the pH test will not be reliable when the FC is much above 10 ppm.
    This disagrees with our standard practice of not mentioning anything about PH beyond keep it between 7.2 (7.5) and 7.8. So the question is: In which, if any, situations is it important to think about PH before shocking?
    30,432
    Re: Lowering PH before shocking
    This adds one more complication to an idea (BBB) that is supposed to be simple. In fact, it must be simple or people will soon lose interest.
    Factually, there really are some cases wherein people maintain their pools perfectly by throwing in pucks and going swimming......all season long. Granted, those are the lucky few and far between, but I personally wish I had that luxury and I would hazard that probably 90% of the people on the forum would, too.
    I think our message has to be pointed at the lowest common denominator, the newbie, who needs to understand the function of chlorine, why he needs CYA, and other basic ideas that far too many of us assume are already understood. Read the threads.....they are not.
    Additionally, it seems the side effects posted above would affect a very, very small percentage of users.
    There is something to be said for covering all situations and we want to be as encompassing as possible but, in doing so, we frequently get mired down in the minutiae that drowns out our overall message of simplicity and ease.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    When a new member posts numbers and states they have a green pool, if their Ph is already above 7.8 I tell them to lower the PH first. That's usually the only time though.
    another one's Avatar
    Jul 2010
    Seattle area, WA
    49
    I think this sentence is the key.
    29,000 gallon, 18' x 44' Indoor plaster pool - 8'x'8 spa in corner. Well water, TF-100,
    pool cover, Pentair MasterTemp 400k btu heater, Jandy RS-4, 4 x 105 sq ft cartridge filters,
    Wisperflow WFE-4 1.0 HP pump for pool, WFE-6 1.5 HP pump for spa jets, MagnaSweep.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I personally vote to not cater to the least common denominator and be accurate. Besides, pH is one of the important parameters that must be controlled. I don't think adding a line to "How to Shock" that says drop pH first is really over the top.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2007
    San Rafael, CA USA
    12,082
    I wrote up the suggestion because of the actual observations in 4JawChuck's post, which wasn't the first time we've seen where shocking at too high a pH relative to the shock level led to issues (mostly metal staining and slow clearing of cloudy water). Lowering the pH prior to shocking is one extra step that can be recommended, not required. His example was extreme due to the very high shock levels, but the principle applies to more normal shock levels, especially if one doesn't have borates for additional pH buffering.
    By the way, shocking is supposed to be an unusual event in the BBB system, so this addition isn't to anything regarding regular maintenance.
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    In this example lets review the "shock" situation and how it relates;
    FC - 60
    CYA - 100
    PH - 8.3 or higher
    The addition of the high level shock (done with Cal Hypo) raised the PH so high the FC was ineffectual until I brought the PH down (muriatic acid) to cure the bloom (which was instantaneous!), it really was amazing to see the cloud of green dissipate and "bleach out" as white precipitate that I could vacuum up with the krawler.
    Since this was two days ago (I drained the rest of the water at FC of 50 to avoid anymore trouble) here are this evenings numbers;
    FC - 12.5
    TC - 12.5
    CC - 0
    PH - 7.5
    CYA - 55
    CH - 250
    TA - 90 (minus the 18.15 correction factor for CYA = 71.85)
    In the past two days I have added 4 - 0.5kg boxes of baking soda (to correct TA) and one 18kg tub of Calcium to give me these numbers.
    This evening I have added another 3 - 0.5 kg boxes of baking soda and .75 litres of muriatic acid to correct the rising PH and boost my TA a little, I intend to check PH in the AM to see if it requires further correction. The past two days have been exceptionally hot and sunny here (34C+) so the FC has been dropping quickly.
    I will say that PH is very important when the CYA is very high and you need to super shock for algae from my experience with this pool which is not typical, if there is anything to add in the "pool school" or "how to treat for algae" section maybe just a notation on how high CYA and low TA levels affect the shock effectiveness which Chem noted in my post.
    It should also be noted that the drain and refill took the better part of 4 days during which I started out with CYA over 200 (likely 250), since I am on holidays I was here the entire time to witness what was going on and luckily could react when the bloom occurred (happened in about 2 hours). In hindsight I think if a person is going to take this long to refill and drain a pool keeping the pool in shock the entire time would be less stressful and better able to cope with the influx of fresh water (from rain and the tap).
    I will say this, the pool has never been bluer or clearer and everyone has remarked on how nice it looks. I went for a swim this evening with the light on and I seem to have some particulates that are not being filtered out so I am not sure if I have ruined my sand filter (channeling) with all the backflushing to drop the water as I was filling. I did the "magic eraser" trick on the liner area above the water line (wow does that work well!) and some of it seems to be bits of eraser floating around.
    Tomorrows project!
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Aug 2009
    North Central Texas
    1,358
    Besides the "off" readings that one gets with high levels of chlorine while shocking, I would like to add that clouding can be a real "confuser".
    I keep my pH at 7.2 with sequestrants to keep the iron staining (not from water supply but from our silt and dust) at bay and to slowly release calcium scaling. If my pH is at or a little above 7.5 additions of bleach will always cloud the pool which may take a couple of days to clear unless I bring the pH back down to 7.2. With 21/7 filtering, using cellulose, just about the finest filtering one can reasonably accomplish, the water stays cloudy until MA is added. And I'm not even talking about unusually high pH here. Addition of MA, to bring the pH back down to 7.2 or a little lower, clears the clouds virtually instantly.
    I can see how, under certain circumstance, this could confuse some people (and those trying to help them) about what the clouding issue is. It took me a while for the light to come on to realize why my bleach additions occasionally clouded the pool.
    A couple of hours ago I added 182 oz 6% bleach. The pump is running and the Aquabot is running. Before the bleach addition I could see a speck on the bottom of deep end; now I can't see the bottom drain. When I test the pH, in a few minutes, and add needed MA, the pool will be clear as it can be in < 20 minutes. I do want to add that my bleach addition did not take the FC anywhere near the level to affect the pH testing.
    I just wanted to add this to the discussion. My circumstances are a wee bit out of ordinary for a "perfectly" balanced pool but I wanted to illustrate that, at times, pH can certainly add to the confusion that may come up when dealing with any level of FC.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    4JawChuck's Avatar
    Jun 2010
    223
    Thought I would write a follow up to this conversation as it related to my situation.
    The shock level of chlorine has abated and I am now on a regular regimen of maintaining FC between 5-9ppm, I had to add a small amount of PH up to bring the PH back into range after the high 50ppm FC subsided when it hit around 15ppm or so. I backflushed the filter again yesterday and my TC immediately went to zero, I feel confident everything is sanitary and the yellowish/green gook that came out of the filter for five minutes was literally a "shocker".
    My numbers tonight are;
    Temp-29C
    FC-7
    TC-7
    CC-0
    PH-7.5
    TA-100
    CH-240
    CYA-60
    I lost FC quickly during the shocking phase but it took a long time to come down under a FC of 10. My CC stayed up there for quite some time until I flushed the filter and then quickly went to zero after, guess it was all trapped in there. No more chlorine smell from the pool and the skin sniff test after swimming yields no odor I can detect so I must be in the sweet spot, my TA and CH readings have stabilized to where they are now and have not budged so I have stopped testing them everyday.
    The "clouding" I witnessed when the bloom occurred certainly precipitated when the PH was corrected and this led to a PH swing that I had to correct as the FC came down over a couple of days, I think the speed that having the correct PH for the FC level which clears a bloom is worth the PH swing if you ask me...being able to vacuum it up right away and flush it from the filter meant the water was clear within a few hours. I'm sure you could let it clear on its own as the FC came down so you wouldn't have to do anything to the PH but I am on holidays and staring at a cloudy pool for that length of time would have pee'd me off.
    I am very happy with the stability of the pool now that I have a couple of "normal" days of regular maintenance under my belt, this won't cost much money to maintain as I lose less than 2ppm FC per day even with a high bather load. I am using Cal Hypo to maintain the FC, I am still dialing in this part of the setup but my numbers today appear to be bang on for the FC level which is the center of the range for my CYA level.
    I need to spend more time getting the amount of Cal Hypo correct for the daily FC usage as even small amounts of it greatly affect the FC level, I can see why liquid bleach is so popular since being out a little won't change things much. I have six jugs of liquid 10% Purox waiting here that I might switch too since it affects PH less and I could just eyeball the amount I am putting in instead of dealing with very accurate Cal Hypo powder weighing to nail it.
    I think I am over the steep learning curve part, moving into a new house at the same time as dealing with this skyhigh CYA level made it stressfull but we are in relax mode now and just enjoying the last few days of holidays seeing a sparkly clear blue pool every morning. It was a probably a good thing I learned this now instead of being oblivious to what can happen, I like being in control of the situation and knowing what to do plus having an assortment of chemicals on hand to deal with anything that might happen gives me piece of mind.
    The funny thing that happened while I was dealing with this is the kids started taking an interest in the maintenance of the pool, I caught my 9 year old out there this morning pulling the cover and skimming the pool and putting in the krawler and turning off the pump to clear the baskets...he even remembered to shut down the heater while he was doing it. He even wanted to test the water to make sure it was OK until I reassured him we were ready to go since Dad had her dialed in.
    I was a very impressed and proud father I can tell you that!
    Avatar is my pool!
    Mar 2007
    San Rafael, CA USA
    12,082
    This post shows another reason why it would be a good idea to lower the pH first prior to a SLAM. It's not just that the pH rises a lot which can risk metal staining and can somewhat lower chlorine effectiveness (if HOCl is the primary killer of algae), but also that at higher pH one loses a lot more chlorine from sunlight. In the example I gave for a SLAM at 40 ppm CYA, the difference between starting with a pH of 7.5 vs. 7.2 is a difference of losing/using 26 ppm FC (assuming the 16 ppm SLAM level is maintained by regular chlorine addition) vs. 8 ppm FC, more than a factor of 3 difference!
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Having read the above, and chem geek's link, I'm wondering why SLAM instructions say to reduce pH to 7.2 to 7.5. Seems like 7.2 (max), or even 7.0 would be the best starting point for a SLAM. Comments?
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    I'm going to add more to that link since it doesn't account for any CYA (or chlorine bound to CYA) direct "shielding" of UV from lower depths, but that would only change the absolute loss numbers and not the relatively higher loss at higher pH. We DID change the SLAM instructions to talk about lowering the pH before the SLAM. In the past, we never said that.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Just throwing in my .2 but adding a note to SLAM instructions along the lines of
    "You may wish to first lower your ph to 7.2, especially if you're on well water or have high CYA. This will help avoid oxidizing metals in your water during the SLAM, reduce temporary cloudiness, and increase the effectiveness of the chlorine."
    would be helpful, AND would give advance warning/tip off people to some of the kinds of issues the SLAM itself can exacerbate.
    It took me a while to unravel these relationships on my own and through the patience of many mods here . A sentence like that would have promoted my ultimate understanding at the outset. I realize, of course, that many don't absorb what's written there now as it is....but it seems a shame to withhold fairly germane information from a careful reader just because others are careless
    PS...even Jack's and Metal Magic have bottle instructions about adjusting ph (in opposite directions). The notion would not be foreign to pool owners
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    One more former noob note --so many people are used to shopping on amazon because like me, they have a cc set up there and don't have to enter new info....as a Noob, I didn't "get" that I should have ordered directly from TFTkits...and I hear a lot of folks say they ordered the Taylor kit on Amazon.
    The amazon vendor most prominent is super pokey in terms of shipping, and in my case a week and a half slid by before I could test. I also immediately wished I'd have supported TFT once I realized what I had done.
    I wonder if the cost of listing on Amazon (but self-fulfilling) would be worthwhile for TFTkits and would be made up in volume given people's preference not to re-enter credit card info. I know it would be better for the noob that way if they just went out and googled for Taylor...better still if both options were linked more prominently so they were clear they could deal with a TFPer. I don't personally feel that would in any way exploit the community nature of the board. Just a thought.
    Helpful Links:
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Interesting read. Wondering if the information above would be helpful to those who have are SLAMming and can't complete it due to cloudy water. A few have cloudy water and pass the OCLT. This may be the answer to their problem.
