Thread: Considering SWG for small pool + Spa
    I'm putting in a small 4800 gallon fiberglass pool into my backyard. There will also be a a spa put in at the same time. The pool will have an Endless Pool fastlane swim current generator in it.
    My question is what SWG would be the best in this situation. I'm a bit concerned about the Fastlane unit, although they say that if the unit is bonded, it's warranty is effective in salt water pools.
    Are there concerns with using an SWG for the spa?
    Help out a total pool newbie.
    Thanks!
    -Eldon
    Fiberglass Ingroung 3850 Gal pool/600 Gal Spa, Intelliflo VS-3050 pump, 240 sqft cartridge filter, EasyTouch system, Intellichlor IC20 SWG. Endless Pools Fastlane current generator.
    Portland, Oregon
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Re: Considering SWG for small pool + Spa
    Eldon I can't help you on which one is the best, but i can say we have a SWG for our spa (& pool) & it works great.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
