Thread: Filter question... I should probably know the answer but
    Jun 2010
    Washington, DC
    56
    My sand filter is ancient. It's so old the multiport has only backwash, winterize, recirculate and filter. I understand the new ones now have six, rinse being one of them. My question is what is recirculate for? The reason I am asking is because the valve pin broke so to backwash we have to insert a nail to attach the valve handle. I can't tell for sure if we're really returning it to filter instead of recirculate after backwashing. My husband said he's pretty sure. My water is balanced and should be sparkling by now after at least a month of shocking, testing, and running the filter 24/7. However, the return is spewing some serious cloudy water after backwashing. We've discussed sand channeling and changing the sand here and here and I know we have a filter problem, just trying to rule out operator error. Thanks a lot.
    Pool size = 24,000 gal.; rectangular 3 ft shallow, 8 ft deep
    Jacuzzi Sand Filter (can't find the model) flow rate 60, Pentair Super Flo, 1HP
    Pool is inground/indoor and white plaster, TF-100 Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Filter question... I should probably know the answer but
    Recirculate bypasses the filter and gives you more return pressure and volume of flow.
    Jun 2010
    Washington, DC
    56
    Thank you woodyp. When we backwash the psi goes down, then it slowly goes back up again when in (what we think) is filter mode. Would recirculate also show increase in the pressure gauge?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It wouldn't. Looks like you're getting it to the right setting
    Apr 2010
    East Texas
    9,569
    No dirt in filter (recirculate mode) equals no pressure increase.
    Jun 2010
    Washington, DC
    56
    Yey, thank you both for a speedy reply.
