Results 1 to 13 of 13
Thread: Mud/soil run off into pool after major storm
    We had a massive storm overnight and dirt/soil/mud has run into my pool and I can't see the deep end. I backwashed as the water level was almost to the level of the patio. I shocked it, and put in my cleaner. The pool was dirty enough that clean tracks could be seen the moment my cleaner started going. Is running the cleaner a lost hope as there is likely much dirt dispersed in the water?
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Mud/soil run off into pool after major storm
    Your cleaner will probably get it all eventually, but you'd be better off vacuuming to waste.
    I'm relatively new to the pool scene. What does it mean to vacuum to waste?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    It means if you're valve has a waste setting on it.........dirt goes straight out to the drain line instead of through the filter. Course your water does too.
    Dec 2009
    Central Massachusetts
    2,690
    You use your hand held pool vacuum that attaches to a pole. Instead of keeping the sand filter on the filter setting, you move the multiport valve to Waste instead. The water ends up being dumped out the backwash hose. That way you dont run all that sludge thru the filter.
    I guess the first question to ask would be do you have a manual, hand vacuum?
    Edit: woody must type faster
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    I do have a manual vacuum. I'm at work so I put in my navigator to clean while I was out.
    Pool store gave me a chemical that is supposed to bind the particles, make them sink for easy vacuuming. Apparently I have to wait 12 hours to vacuum. Pool store says if water is not clearer by tomorrow morning after putting in this binder chemical, pool will likely have to be drained.
    Dec 2009
    2,690
    What they sold you is called floc, or flocculant. It's generally not needed. Just use your manual vacuum and keep removing the dirt. The filter will also help remove the mess as well. You need to have some pool owner patience or whats also known as POP. This only happened yesterday, correct? Drain the pool, thats non-sense. It will take a bit, but you can clear it. I wouldn't use the floc, it will make a bigger mess than what you have now.
    So, I vacuumed to waste, water is still cloudy but if you stand on the side you can see the deep end. From my bedroom window, you cannot. Anyhow, the pool store is run by my PB and they just gave me the flocculant. When I vacuum, it just stirs up the dirt, so how will the chemical make a bigger mess? Also, how can I tell if an algae bloom from the heavy rain is not partly causing the cloudiness? The reason I ask is we had one a couple weeks ago after a heavy rain. No mud though. The mud is from my neighbor removing the concrete slab under his eaves trough drain, thus creating a huge mudhole which ran under the fence into the pool.
    oh-boy-flooding-rains-last-night-t22674.html
    Takes a few days, but fastest way back, imo.
    32k Gallon Vinyl IG, Hayward 75 DE, 1 HP, Chlorine. 4 top skimmers, 1 bottom skimmer. 2 top returns, 1 bottom return.
    I did use the floc, three times and the water appears clear. Problem is, once you are in, and use goggles it has a hazy look to it now that we never had before. No more dirt appears to be piling up on the bottom. Any idea what would cause the 'hazy' looking water? Water looks clear from outside the pool.
    Dec 2009
    2,690
    More than likely floc residual. It will take awhile to clear. Have you tested the water?
    If your cleaner has a filter screen on the water inlet like my Polaris does, you may want to check it eventually to be sure it is clear of floc.
    Though I've never used floc, I suspect that the prior owner did, for I found some gummy clear stuff in the inlet filter screen of the Polaris when I checked that after the pressure relief valve failed. No evidence that it caused the failure as far as I can tell, but it could have helped.
