Results 1 to 9 of 9
Thread: Recommended bromine levels
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    I have been looking around in TFP but cannot seem to find recommended levels of bromine. Would it be the same as the recommended chlorine levels times 2.25?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    30,403
    Re: Recommended bromine levels
    On most OTO chlorine tests, the equivalent bromine is marked on the opposite side of the chlorine. Do you have a bromine pool?
    Bromine is not affected by CYA, so the Chlorine / CYA chart does not apply. The normal day to day bromine level should be 3 to 5. Shock level is around 10.
    Apr 2010
    Fleming Island, FL
    431
    Thanks Jason, thats what I was looking for. Is this recommended level for bromine listed anywhere on TFP? If not maybe we could add it to pool school somewhere??
    Carlos
    We don't recommend the use of bromine, except in a spa. We don't normally list information on how to use products that we don't recommend. The spa directions are different than the pool directions, so they don't apply.
    Apr 2010
    Fleming Island, FL
    431
    Jason, I need it for my spa.
    Carlos
    If you are talking about a spa, you should be posting in the Spas and Hot Tubs area. If you post here and don't say otherwise, we assume you are talking about a pool.
    There are good instructions on using bromine in a spa in this topic.
    Apr 2010
    Fleming Island, FL
    431
    Sorry Jason, I was originally going to put it in spa but since it is chemistry and some people do put bromine in their pool I thought this would be the better place. Little did I know that bromine is no good in the pool.
    Carlos
    Its not that it is "no good", it is just that chlorine is enough better that there isn't really any point in thinking about bromine for a pool. Bromine is more sensitive to sunlight than chlorine is when using CYA, so you end up spending more money, and many people object to the "chemical" smell. Bromine is more stable at the high temperatures in a spa, so bromine is better in a spa, but in a pool chlorine is the clear winner.
