Results 1 to 9 of 9
Thread: Filter Problem
    Filter Problem
    I have a DE pool filter. The DE appears to be coming out the pool jets and my preasure is around 25. When I backwash my preasure will go down to its normal level of 15 but slowly climbs back up. I have replaced the grids (fingers) on the filter 3 years ago and it has worked fine. My motor is less then a year old. Is it possible I need a new filter all together? The price I was quoted for a new filter was $975.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Filter Problem
    Welcome to TFP.
    What filter and pump do you have?
    I'd be thinking it might be time to open the filter and clean the fingers.
    South Central NJ
    3,192
    Re: Filter Problem
    I suspect it's a Hayward bump style filter. Sometimes the rubber diaphragm gets a small tear and needs to be replaced. Another possible is the fingers are not full seated, one or both O-rings on the center shaft between the plates is worn or you have a bad finger.
    Any way you slice it, you're opening the filter to clean it and find the culprit.
    Scott
    Owner of - PoolGuyNJ LLC
    Re: Filter Problem
    Yes it is a Hayward motor and I believe a Hayward De-690 filter. I've cleaned the filter twice this year so it can't be dirty fingers. I also replaced the fingers 3 years ago. I'm not sure what the rubber diaphram is but I will check it out. The O rings could be a possibility. Sounds like I might not have to replace the filter. Will fixing these reduce my pool preasure? Thanks for your help.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Filter Problem
    Welcome to TFP!!
    How does the water look? If it;s green, the filter is getting filled up with debris pretty quickly.
    Luv& Luk
    -Ted
    South Central NJ
    3,192
    Re: Filter Problem
    If you ran with a high calcium level and the pH fluctuated on the high side, or you have swimmers that use copious amounts of tanning lotions and sun blocks, pets, etc... the fingers may need a TSP bath and an acid bath.
    Scott
    Re: Filter Problem
    I put a new O ring this morning and added fresh DE. My other DE was a few years old. This seems to have helped my preasure is down. Now I'm waiting to see if it holds the dirt in. I have been battling Alge but I'm figuring that is because of the high heat. My PH level is good. If the O reing doesn't slve I will bring the grid into the pool store to check it out.
    30,415
    Re: Filter Problem
    BMAC,
    If you still have algae, your psi will continue to rise as the filter gets out the dead algae.
    I think if you address your filter issue as a water quality issue, your filter issues will disappear once the water gets cleaned up.
    Re: Filter Problem
    I'm still battling the alge which could be raising my PSI I'm slowly getting back up to 20PSI. The dirt on the bottom is getting less and less as i sweep and have the Polaris clean. The water is clear. So I'm hoping that I can get the pool clean and backwash the pool to keep the PSI down. The new O ring is definitely helping. Next step would be to test my grids for a tear.
