Thread: Pressure cleaner plumbing
    Jul 2007
    Western East Texas
    Is there any reason that a dedicated pressure return cannot be hard plumbed? I am helping a friend recover their pool and have noticed that the Polaris pressure hoses for this application have become unservicable. The suction side has collasped and is entraining air. It uses a Polaris 3/4 hp booster pump and is going into a 1 1/2" return line. The hoses currently used are about 3/4" in diameter. Would it matter if the piping was larger than 3/4"? I would imagine that it wouldn't matter as long as there was sufficient pressure to operate the 360 cleaner.
    I tried the Polaris web site, but couldn't find any plumbing instructions.
    Thanks for the responses.
    5450 gallon 18' Intex Easy Set, Dynamo 3/4 hp 2 speed pump, 200# sand filter, Intex swcg, k-2006 test kit
    You can use a larger pipe as long as it is rated for the pressure involved. Since schedule 40 PVC is rated for over 100 PSI and a pressure side cleaner is generally around 50 PSI using standard schedule 40 pipe and fittings will be fine. Since the flow rate is low on a pressure side cleaner the 3/4" flexible tubing is sufficent and is easier to work with, but no reason you can't use something else.
