Results 1 to 9 of 9
Thread: Is Adding a Return to AG pool a DIY project
    Jun 2010
    San Antonio
    424
    I have only one return and I would like to add a second and convert to PVC plumbing. I am comfortable with working with PVC, but have no experience with cutting a hole in the above ground pool and vinyl liner. Is this something that I can do or do I need to get a professional to punch the hole?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    22,542
    Re: Is Adding a Return to AG pool a DIY project
    There was a thread a while back where someone used a hole punch to cut the hole in an AGP for a second return. That's the best way to do it. You could do it with a hole saw but they might snag the liner and they leave a rough hole. If you could rent a hole punch that would be best.
    Rocklin, Ca
    467
    Greenlee is a company that makes punches.
    Here is a link to some that Mcmaster Carr sells. http://www.mcmaster.com/#knockout-punches/=82qjw0
    You could do better price wise if you look around.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Jun 2010
    San Antonio
    424
    I will check to see if I can rent one first as I do not imagine I will need it for any other project. If I understand the process - I will lower the water to below the return level - Drill a "draw hole" of appropriate diameter through the liner and the wall and then use the hole punch to cut through it all. I guess the return fitting comes with a gasket. If this is all there is to it I don't see why I can't do it myself.
    Thanks
    Larry in Texas
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by Txmat
    I agree. Sounds pretty straight-forward.
    22,542
    It is pretty simple and the bonus of using a hole punch is that you get a perfectly round smooth hole in the liner.
    The return comes with all the gaskets you need to install it correctly.
    That'd be me. It's pretty simple. Pictures are here buying-a-used-agp-t16890-180.html 'bout half way down the page... The only difference is you will be going through the liner also. Have fun!
    Don't forget to paint the exposed metal from the cut! Fingernail polish works.
    Guess that wasn't me... I didn't add a second return. Just put one in.
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Jun 2010
    San Antonio
    424
    Thanks Rob. Good photos and description. As soon as I finish a little deck and pool repair I will tackle the re-plumbing including adding the return.
    Larry in Texas
    I'm not sure you can rent just the size you need, but you should be able to rent a whole kit of different sizes for a few bucks. Maybe they'll part with just one, guess it depends on the rental shop.
    Rob B
