Thread: Algae in Filter's sight glass
    Jun 2010
    Toronto, Canada
    34
    I've been successfully using the BBB method for over a month now. Recently, I went away for a few days and when I returned I noticed that there was some algae starting to form on the bottom of my pool. I shocked the pool and then noticed that the Sight Glass on the Filter has what looks to be green algae covering the bottom half of the glass. I backwashed for a couple of minutes and this didn't clear it up.
    Is this a sign that there's something wrong with my filter or will the shocking process clean this part of the filter as well as the pool?
    20,000 Gallons Inground Vinyl Pool, 1 skimmer, 1 floor drain, 4 return jets, 1 vacuum intake
    Hayward Vari-Flo XL sand filter (SM2506T), Hayward EZ Flow Pump (SP-3107X10), Emerson Pump Motor (EB228), Hayward Comfortzone NG Heater, Hayward Chlorinator (CL220)
    22,543
    Re: Algae in Filter's sight glass
    The shocking process will take care of it as you backwash. If you want it clean faster just unscrew it and bleach it a bit.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Don't sweat the sight glass, it has water in which all the chlorine has been used up with no way to replace. However, it's not a problem because that water doesn't come in contact with your pool's water
    If it's for aesthetics, follow Bama's advice
    Luv& Luk
    -Ted
    Jun 2010
    Toronto, Canada
    34
    Thanks for the info!
