Thread: Trying to locate a leak??
    Hi all,,,,,got all the dead algae and dirt out of the pool,,,,,it looks and feels wonderful. . Thanks for all the great advice.
    Ok,,here is the new issue;,,losing water in the pool. I have looked and looked and can not find a spot to do the food coloring test. Is ther another way to "find" where it is leaking? All is dry on the filter and pump area. I did the bucket test and the pool lost more than the bucket. So, I am guessing that it is not from evaporation.
    I have a 24 ABG, sand filter, 1.5 hp waterway pump
    Use BBB method,,,and love it.
    Any and all advice greatly appreciated,,,Heidi
    30' x 52" round above ground
    Cartridge filter
    2 stage pump 2 HP
    inline chlorine feeder (slowpoke jumbo tabs)
    HTH 6 way test kit
    Aquacheck Select test strip
    22,550
    Re: Trying to locate a leak??
    Look at the waste line while the pump is running. If it's leaking out some, there's your leak! If it is it's most likely the spider gasket.
    If it's not that post back and we can tell oyu how to narrow it down farther.
    Looked at the waste line and it is dry.
    Cartridge filter
    2 stage pump 2 HP
    HTH 6 way test kit
    22,550
    Does it leak more or less with the pump running than with it off? You'll probably have to run a couple of test to determine that.
    I don't know,,,we run the filter 24/7.
    Cartridge filter
    2 stage pump 2 HP
    HTH 6 way test kit
