Results 1 to 7 of 7
Thread: How long can you wait after getting sample before testing?
    another one's Avatar
    Jul 2010
    Seattle area, WA
    49
    I tried searching for this answer, but "wait" gets lots of hits.
    So my pool water is cold - 63 degrees, and I want to let it warm up for about 4 to 8 hours so I can test CYA. So can I just wait and test everything or do I have to test pH, FC, etc. now and CYA later?
    Also, can you wait days before testing - like mail a sample to someone and have them do a test?
    Thanks as always.
    29,000 gallon, 18' x 44' Indoor plaster pool - 8'x'8 spa in corner. Well water, TF-100,
    pool cover, Pentair MasterTemp 400k btu heater, Jandy RS-4, 4 x 105 sq ft cartridge filters,
    Wisperflow WFE-4 1.0 HP pump for pool, WFE-6 1.5 HP pump for spa jets, MagnaSweep.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: How long can you wait after getting sample before testing?
    No, you have to do the test fairly quickly.
    To warm up the CYA sample just run the bottle under warm/hot water.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    What is the reason for warming the sample?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Mar 2007
    San Rafael, CA USA
    12,082
    To speed up the rate at which it forms the cloudy precipitate so that measuring after 30 seconds of mixing gives you a reasonably accurate result.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I don't think CYA will be affected by waiting, it's there or it isn't. pH will change with time. Try it yourself: take the reading as soon as you draw the sample. Then set the color block aside while you do the rest. See if it didn't move a little. Shake it up good, it will definately change. But I digress. Chlorine will dissipate with heat, sunlight, and air. So it should also be done fast. CYA endures. Oh, how I wish it would disappear on its own......
    FC, CC, and PH can all change fairly quickly if you leave the sample sitting. TA, CH, CYA, Salt, Borate all stay more or less the same when the sample is left sitting.
    Jul 2010
    Seattle area, WA
    49
    Thanks for all the info. I tested with fresh water and did the hot water bath to get it above 70 degrees. New pool heater showed up today, vent pipe is coming on Tuesday. So hopefully, we'll have a warm pool next week.
