Thread: TA, FC issues
    TA, FC issues
    Here are my latest numbers from TF-100 testing:
    FC -- 14.5
    CC -- 0
    pH -- 7.8
    TA -- 150
    CH -- 240
    CYA -- 60
    I have a 6-week-old pool. I'm told that the TA will be high on new pools, even pebble surface, for the first 30 - 60 days. I'm working on bringing the FC down by reducing % on salt cells. Is this cool, or do I need to be working on anything else?
    39,000 gal 48 x 22 gunite/pebble, SWG
    Pentair Intelliflo
    Jandy Aqualink RS; Jandy 60 DE Filter
    Polaris 280 Black "Manta Baby"
    3 Jandy WaterColors LEDs
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: TA, FC issues
    You need to keep the PH under control - not worry about the TA, that is secondary to the PH. Keep the PH at about 7.6 and you should be fine. The TA will slowly come down over time as the surface cures, because the acid you use to keep the PH in check will also control the TA.
    We recommend Muratic Acid for controlling PH/TA.
    What % is the setting at now?
    Re: TA, FC issues
    I have two salt cells, each set at 45% now.
    Pentair Intelliflo
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: TA, FC issues
    Try lowering them to 25% or so, then test each day and see where that gets you. It takes a little bit of fiddling to get it just right, but it won't hurt anything to have it a little high while you figure it out.
