Thread: Use of TF-100 test kit in Bromine Pool
    The TF test kit site referred me to your forum to answer the following question:
    I am using the TF-100 test kit with a bromine pool and need to
    know how to convert the FC and CC test results to bromine. The FC is
    at 16.5 and the CC is 1.5. Thanks for your assistance.
    central florida
    11000 gallons, pebbletec
    SWG-Auotpilot Digital SC-36
    DE filter, 2 hp pump
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Use of TF-100 test kit in Bromine Pool
    I know that you multiply the FC reading by 2.25 to get the bromine level. The CC is a different story, one of the experts will have to answer and I am not sure how CC even applies to bromine water chemistry.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    thanks.
    central florida
    Apr 2010
    Fleming Island, FL
    431
    Bump
    Carlos
    Mar 2007
    San Rafael, CA USA
    12,082
    You don't measure the CC and it's not relevant anyway. Bromamine is a reasonable sanitizer and it apparently registers in the FC test along with bromine. Just for the heck of it, you could try adding the 5 drops of R-0003 to see if you ever get any pink.
