Thread: winterizing with bbb
    Jul 2007
    pacific nw
    92
    ok..the bbb method is working well for me this 1st year i've tried it..what do we do over the winter once i've drained water below lowest hole & put winter cover on (or b4 that i should say) i'm guessing this will happen late sept sometime, anything special to do to the water?
    Typically you double check that the PH is adjusted properly, shock the pool, and add some PolyQuat before closing.
    Aug 2007
    Northeastern Ohio
    178
    Do you shock before or after lowering the level of water?
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    Shock before lowering the water. You want the pump running when you add chlorine to get it well mixed.
    Casey's Avatar
    SW PA
    10,448
    Thanks for this thread colormesummer! I wanted to know the same thing!
    I was going check pH, add chlorine and polyquat, then drain and cover but wasn't sure if that was the right way.
    HA! My guess was right! 8)
    Thanks alot!
