Thread: AGP bottom rail question
    We are currently installing a used 38 x 18' doughboy with 7' deep end. Hoping someone can help as we have currently installed the side rails with pressure pads. The side rails were dug in flush with the ground and cemented in. The bottom rail locators which attach to the bottom rails are about an inch above so the bottom rails sit above the compact dirt by about 1". The pictures in the directions are not clear but I am assuming that the bottom rails should have something solid under them? Can sand be put in? We are putting 1 x1 cement pads under all the vertical end cap joints on the curved ends as well. Hope someone can help!
    18' x 38' Doughboy AGP with 7' deep end.
    22,548
    Re: AGP bottom rail question
    Can you post a picture of the side and bottom rails. I can't picture what you're saying. When mine was installed the uprights were dug down so that the bottom rail sits flat on the compacted earth.
