Results 1 to 8 of 8
Thread: How to replace Polaris 380 belts
    Jul 2007
    Austin, TX
    61
    I need to know how to replace the belts on my Polaris 380. I don't want to break anything by forcing parts apart. Do I need to remove the wheels? I took off the cover and removed the two screws by the front wheel thinking I would be able to take the wheel off so I could slip the new belt around the gear. However, doing that just loosened the peice behind the wheel that the axle goes through but I still can't remove the wheel.
    I'm sitting here with the Polaris in pieces so I'd really appreciate some help!
    26K IG plaster pool, 2 Baker Hydro Skimmers (Model HS), 4 return jets (one plumbed with a PoolSkim surface cleaner), Hayward 1.5 6-way Multiport Valve (Sp710x-All), Polaris 380 w/ Polaris PB4-60Q Halcyon 3/4 HP Booster Pump, Pentair SuperFlo 1.5 HP (1.65 SFHP) Two Speed Pump (SF-N2-1-1/2A), Stainless Steel Hayward vertical DE 36ft2 filter (Duralon tank model DE3600), Purex CHD Pool Star light, 2 Intermatic mechanical time switches controlling the filter pump and booster pump, Hasa 8 gallon 3/8" Pool Liquidator Chlorinator, 1.5" return line with 3 x 1.5" suction lines, Austin, TX
    Re: How to replace Polaris 380 belts
    I've replaced several, but without one in front of me, I for the life of me can't visualize - which is odd cause I can tear one down and put it back together now faster than Jeff Gordon's pit crew changes his tires. IIRC correctly, you'll have to remove the two screws that hold the wheel on to let the wheel's gear slide back a little bit - on at-least one side in order to get the belt in. You may also need to remove the little clip that holds the wheel on. Hope this helps.
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Jul 2007
    Austin, TX
    61
    Hi taekwondodo,
    Thanks for the info. I got that far after I posted but I still don't know how to take the wheel off; assuming I have to. I don't see how I can get the belt on with out taking the wheel off. Can you at confirm that I need to take the wheels off to change the belts?
    Attached is the Polaris 380 Rebuild Kit Instructions. They aren't too helpful but at least provide some diagrams to help describe the parts.
    Here's what I've done so far:
    1. I removed one side of the base cover; the side that the belts are on.
    2. I removed the hubcaps and the E-clips right behind the hubcaps on both wheels which also allowed me to remove the inner bearings.
    2. I removed the two screws on both axle blocks. The blocks are now free.
    The problem is the axle is still attached to the axle block on one side and the wheel on the other side so I can't slide it out of its hole. I just looked at the diagram again and it shows another E-clip on the other side of the inner bearing (and perhaps on the other side of the wheel itself). I didn't notice it when I was searching for a way to get the wheel off but I'll have to look again at it when I get home. Can anyone confirm that this E-clip needs to come off, if there are any tricks to getting access to it and geting it off? Hopefully, this is all I need to do to get the wheels off so I can get the belts on.
    And I thought it would be simple to change the belts!
    Attached Files Attached Files
    w/o pulling one apart... IIRC, you should remove the e-clip on the outer side of the wheels on the side with the two wheels. both wheels should then be able to be removed and you should be able to slip the belts on then.
    Oct 2010
    Temecula, CA
    122
    This is an old post but I hope someone gives it a read. How do you remove the e-clips on the side of the wheels of the Polaris?
    I have to replace the belts myself and I have taken these apart before but not taken off the wheels to slip on the belts. I think I'll replace them both so I don't have to do this again!
    Thanks
    Anne
    Temecula, CA
    16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide
    Whisperflo pump; Pentair SMBW 4000 Series filter... that's all I know! Still learning....
    Oct 2010
    Temecula, CA
    122
    Just as well.... figured it out with DH. I'd never seen an e-clip. Amazing what a search on the internet turns up!
    Temecula, CA
    Jul 2007
    Austin, TX
    61
    For those who come across this post and want to know how to remove the e-clips; it's very easy. First, take the "hubcap" off the wheel. If you look at the side of the "hubcap" you will see a space where you can slip in a flathead screw driver and gently pop it off. Then, wedge the corner tip of a flat head screwdriver between the exposed middle curve of the e-clip and the wheel axel and pull it sideways; away from the axel. It should just pop out.
    Aug 2007
    near the swamp
    806
    I wish I would've saw this thread earlier, I would've done a step by step process with pics.
