Thread: First readings with TF-100
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    FC 5
    CC .5
    TC 5.5
    pH 7.5
    TA 220
    CH 390
    CYA 10-15(the dot is almost gone, can barely see it)
    It's been 8 days since I added CYA. Should I wait a couple more days before I add more CYA?
    And what should I do about the TA & CH? Off to read more in the pool school.
    I should add that it has been raining here every night. It's at the overflow point right now. But, I don't want to backwash to lower the water level cause I'm trying to raise my CYA.
    5,000 Gallon 16'x 48" Intex Ultra Frame, Waterway 1hp sand filter, Intex SWG, AquaCritter, TF100
    Climate/Location: SW Iowa
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: First readings with TF-100
    On the CYA test you want the dot to be completely gone. Sounds like your CYA is zero. It should have shown up after 8 days. There have been reports of people buying CYA that doesn't actually have any CYA in it. Looks like you need more.
    Did you wipe the tip of the dropper with a clean, damp cloth while you were doing the TA test? There is an issue with static building up causing small drops. If not, re-do the TA test wiping in between drops.
    The CH level is not awful, and I withhold comment until you re-do the TA test.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    I used HTH stabilizer & conditioner.
    Okay, I redid the TA and got 130.
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    Well, I added CYA last night(sock method). And checked levels again this morning.
    FC 8.5
    CC .5
    TC 9
    pH 7.5
    TA 110
    CH 230
    CYA 65
    Can my numbers really change that much over night?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    No, most likely testing error.
    How much stabilizer in total have you added each time?
