Thread: Sudden Low Pressure in Spa
    Jun 2010
    Fort Worth TX
    2
    Hello everyone. Had a situation yesterday, put my pool system in spa mode and turned on spa drains so I could suck all silt and dirt back to the filter. Im in the spa with goggles pushing sand/silt into drains when all of a sudden the jets stop "blowing". I know theyre not really blowing unless I push the air button but, you know what I mean. The water pressure stopped. So, I went shut the system down, checked the strainer basket and had quite a bit of mown grass in there from the previous mow. Cleaned it all out, started the system back up, filter pressure is normal, everything is fine but, low pressure on those jets when in spa mode. Any advice? Thank you.
    Billy
    26,000 gal. in ground Gunite pool w/attached spa w/5 jets, 2 drains and 1 return. Aqua Pure SWG-APURE 1400, Jandy DE Filter DEL60, Jandy Pump Stealth SHPM2.0, Jandy Propane Heater Model LT, Polaris Blower Model 1-460-02 1HP.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Sudden Low Pressure in Spa
