Results 1 to 12 of 12
Thread: New to this forum
    Jul 2010
    Connecticut
    12
    New to this forum
    Hi everyone. I am new to the forum and have just ordered a T-100 test kit. Right now I am using a combination of trichlor pucks and liquid bleach. I have a small amount of green around the edges of the pool floor. Once I get my test kit I will post results.
    30 ft. round 52" deep above ground pool, about 20,000 gallons
    Starite cartridge filter with 1.5 GPH pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New to this forum
    Welcome Kenny
    22,544
    Welcome to TFP and we'll be waiting on those results.
    Jul 2010
    Connecticut
    12
    Got my Taylor's test kit and here are the results:
    FC 13
    CC 0
    TC 13
    PH 7.8
    TA 300
    CH 200
    CYA 30
    The pool had alot of green on the bottom yesterday so I vaccumed and shocked up to 13. Overnight FC drop test still shows FC at 13 this morning. Most of the green has cleared out overnight. My CYA is a bit low so I was thinking of running with TriChlor for the rest of the season...till early September. This would help lower my PH too which is also a bit high. What do you all think ?
    If you begin using the trichlor pucks, I suggest calculation how many it would take to raise the CYA to the level you want, then retest CYA at that point. It may not have gotten that high, since there is some loss of CYA over time, but you do want to be on top of that. And you will keep up on daily or every other day tests of FC since depending on how it is added, you may need a small chlorine boost via bleach or something to keep the levels up. I do notice that TA is high, and MA could lower that which would also help keep pH from rising so fast.
    Jul 2010
    Connecticut
    12
    I could also keep FC in the 2-4 range and use bleach for the rest of the season, given my low CYA. Probably wouldn't need too many jugs per week to keep that level.
    30,414
    Hey,
    Welcome to the forum. This quote doesn't seem quite right...
    A pool with visible algae should have consumed a lot, if not all of that chlorine. You must have added some chlorine or had a testing error.
    Chlorine kills algae but in doing so, it is consumed.....your FC should have dropped if it cleared up the algae.
    Jul 2010
    Connecticut
    12
    I vacuumed alot of it out to the filter and then cleaned the cartridge. I added about 2 gallons of bleach and tested a few hours later. FC at 13. Tested again this morning and still 13. I'll test it everyday.
    30,414
    I hear ya', but something is still not right.
    Vacuuming does not remove nearly all the algae from a pool. Chlorine does and you should've experienced a drop in your chlorine. How does your water look now?
    Jul 2010
    Connecticut
    12
    It looks clear but not sparkling clean. It needs another vacuuming and skimming. We have had thunderstorms here and I get some pine tree droppings. I really thought the FC would drop overnight.
    30,414
    I would suggest just chalking up that FC non-loss to one of those unexplained mysteries. My point in bringing all that up along with your water quality is whether or not you need to shock. I'm still not really sure.
    Perhaps the best thing would be to simply elevate your FC somewhat (around 4-6ppm) and keep it there for the next few days. Then do another overnight FC loss test and see what you get. I'm thinking that elevated FC will help clear out any remaining algae and should have your pool sparkling soon.
    Jul 2010
    Connecticut
    12
    You mean elevate FC to 20 ? Or 4-6 ? I am already at 13.
