Thread: Just joined the borax club
    Jul 2010
    IL
    201
    Just joined the borax club. How long after adding the borax and MA until you can get back into the pool?
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: So you want to add borates to your pool--Why and How
    As soon as everything is thoroughly mixed and you're sure pH is in range
    Jul 2010
    IL
    201
    Sweet.. I have a few Ph monitors from having a couple salt water reef tanks. I have one sitting in the Skimmer box and Ph is currently 7.48 without any aeration.
    gqjeff,
    Where can i get one of those PH monitors?
    Will you be interested in selling one?
    Thanks.
    _________________
    35k gal 850sq ft french gray plaster, Jandy JEP1.5HP ePump, Pentair 60sq DE filter, Pentair Intellichlor IC40, 10 Fafco sunsaver 12'x4' panels with Goldline GL35. Laars lite 325k BTU NG heater, Hayward Colorlogic 4.0 LED light. Plumbing: 2" PVC, No main drain, four 1" returns, 1 skimmer with 2 wall drains, one 1.5" suction cleaning port.
    Jul 2010
    IL
    201
    This is the one I have in my Skimmer. Its not waterproof so you can not leave it in the pool. I get roughly 7.5 on the test strip so its pretty accurate. I just calibrated it to make sure. Seems nothing in the pool throws off the reading either. I use ph controllers on my tanks that turn on/off co2 when its not needed.
    http://www.fosterandsmithaquatics.com/p ... catid=4482
